#21 |
Try disconnecting the battery just before making a run. This should put the computer in open loop (learning mode).
I had to do that on one of my turbo cars. If I didn't it would slow up at least 1 to 1.5 tenths no matter what temp air etc.
Art Leong 2095 SS |
#22 |
Art, thanks for the tip. Disconnect pos. and negative sides? We are running a 4:88 gear. shifting at 5800 1st to 2nd and 5800 2nd to 3rd.
60' 1.76 330' 5.29 1/8th mile 8.37 1/8th mph 79.53 1/4 mile 13.37 1/4 mph 97.34 |
#23 |
Liked 5,121 Times in 1,952 Posts
Marc ,You can make 11 lbs @ 2800 against a 2 step?
How long does it take to get there?
#24 |
Liked 53 Times in 25 Posts
I like to know also.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
#25 |
How? Heck I don't know!
![]() Like i said, I just started this deal; sounds like I shouldn't be getting that much? I will pay closer attention this weekend. Hope to test on Friday and we have a combo race Saturday where I will try and get as much info for you guys, just tell me what to look for. I do go to full throttle as soon as i stage to get the boost as high as possible. Do you think it would help to add brake pressure and be able to leave at a higher rpm? Last edited by Marc Kinton; 12-10-2009 at 07:38 AM. Reason: more information |
#26 | |
You said "stock brakes" . Is that stock vacuum assisted brakes?
#27 |
Don't fool it, just reprogram it!
Rob Lloyd 3728 BF/S |
#28 |
What he said^^^^^
If everything goes the way it suppose to and I get out there in Stock next year, it will be my first reall attempt at bracket racing a turbo car. I am a little afraid that .05 off will not be to uncommon. I think the boost off the line will be the key. Ah well, I have no grandiose dreams of going rounds unless heads up runs. A record, and a number 1 qualifying spot will be my goal next year. From there I will see if I will campaign the car a second year, or move on to a consistent car. |
#29 |
Best of luck. have fun.
One thing I believe to be true is, don't mess with the hairdryer. All the cars I know that don't do that, are consistent. My car almost always ran the number (within a hundreth or two). But my reaction times were so bad I couldn't go rounds. Mark Poole in a turbododge finished in second place points in stock/superstock combo 2 years in a row at the "Hill" in Nashville. And there were a bunch of heavy hitters running there back then. So you can go rounds. My car was most consistent running it hard, running overweight but not shortshifting or playing with the boost..
Art Leong 2095 SS |
#30 | |
I also think boost and traction off the line are key. Because turbos need load to spool; the better your traction, the faster the boost will build. I think getting the traction off the line consistent is key. And, that's doubly hard if you're FWD becuase the 'groove' is 8ft behind your slicks...
