Liked 685 Times in 204 Posts
Any recommendations on where or who can still acid dip or chemically strip doors/fenders etc.? Thanks, Dyno
Liked 44 Times in 20 Posts
Dave Kaluasa
248-866-3995 I know he did some stuff for Wayne Hutton on his SS'er. |
Liked 5 Times in 3 Posts
I have a source here in Michigan that I have used for 20 years.
Bruce Witherspoon 3656 SS/KA |
Liked 13 Times in 7 Posts
I am in the Mpls./St. Paul, MN area. Upper midwest location would work best. How about that .15 hit I took yesterday! Thanks, Dyno
Same one that Chrysler used in the 60's?????????????
Dick Kirkpatrick 3033 SS |
I really don't think so.
Be cautious with chemically stripping any automotive part that the metal overlaps, such as a door. It is nearly impossible to get all of the stripping agent out from between the seams. You may think you did a good job of washing the seams but the part will leach stripper even after what you thought was a thorough job.
A friend put together a beautiful 64 Dodge Dart in which the doors had been chemically stripped. The acid leached out onto the new paint corroding it, making a mess of the fresh paint job. He went as far as taking the doors off and tried to thoroughlly clean out the seams sealed and repainted with no luck. It got better but they still leached the stripper. He ended up putting on two doors that were blasted with plastic beads. As a rule I will chemically strip parts with no seams and bead blast the parts that do. Just my .02 cents.
Nelson Kowal Stock 345 Last edited by njk53; 10-30-2009 at 07:45 AM. Reason: Spelling |
When stripping with acid the acid must be neturalized with a high ph (alkaline )then rinse with a iron phosphate that will hepl neturalize the alkaline. Wait with about a week before priming to allow all moisture to dry.Then use a 2 part self etching primer.
Bruce,
How can you dip fiberglass?
Chuck Beach 3340 STK |
