Old 10-19-2009, 06:59 PM   #1
Mike W
Mike W's Avatar
Default MSD ignition help!!!
I have a MSD 6al ignition on my car and billet MSD distributor. Since I put the car together Ive had trouble with it starting, it only has 11.1 comp, someone suggested a switch to flip the ignition on once the motor started turning over, but as soon as you flip the switch it turns slow. i have a Tilton mini starter and ive run a ground from the battery to the motor and a ground from the motor to the frame. The 6al was the only thing i didnt buy new. Can the ignition box drain a battery? Can it also put total timing at start even if the distributor isnt locked out?
Mike
Mike W is offline   Reply With Quote
Old 10-19-2009, 07:32 PM   #2
Default Re: MSD ignition help!!!
It is not likely that an MSD box will drain a healthy battery while you're starting the car. A 6AL, wired correctly, won't alter the timing, it'll only process what the distributor sends it.
Have you had the battery(ies) thoroughly tested? Are you certain the timing is correct? Are you certain the box is wired correctly?
It is possible that the box is bad, but normally if it runs well once it started, there's something else wrong. If it doesn't start well AND it doesn't run well, I'd look at the box. But you need to check the wiring thoroughly first. It'll do all sorts of stupid stuff if it is not wired correctly. Check to make sure it gets enough voltage when cranking, and make sure the box itself is properly grounded, and the 12V connections are good.
Old 10-20-2009, 06:38 AM   #3
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
We had the same problem with one of our cars, we had the battery feed going to a distribution block and then to the starter. We switched it direct to the starter and then from the starter to the distribution block and now it starts like a charm.
FrankM is offline   Reply With Quote
Old 10-20-2009, 07:48 AM   #4
njk53
We had an Optima battery in our car and it was doing the same thing. I couldn't come to grips that this high dollar battery went south on us. It turned out the battery just got old and couldn't handle all the electronics in the car. New battery did the trick.
Check your alternator too. Should be putting out a touch over 14 volts.
Nelson Kowal
Stock 345
Old 10-20-2009, 07:55 AM   #5
Bob Shaw
Liked 317 Times in 62 Posts
Mike,
Try bypassing your neutral start switch.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 10-20-2009, 07:58 AM   #6
buzzinhalfdozen
Liked 11 Times in 8 Posts
If the motor turns normally without the ign. being turned on than you could assume that all is well with the starter and battery. The MSD shouldn't use over app.20 amps try turning the timing WAY back and retest, you may just have far too much timing initially. This is an easy test to do only requiring you turn the dist. to test, I've seen MSD unit have different actual timing than a OEM unit. Joe You can also check the timing while you're cranking the motor over, just to be sure it's not too advanced.
Joe Buchanan SS/BX 3117
Old 10-20-2009, 09:09 AM   #7
Bill Edgeworth
You should check the voltage the MSD sees during cranking. An MSD box will not operate properly if it sees less than 10 volts. Also if you have an Optima battery they operate at about ½ volt lower than a conventional battery. They are good batteries but put you ½ volt closer to your box not working if you are experiencing major voltage drop during cranking. Cranking voltage drop is one of the reasons most ignitions have a direct to battery lead to bypass all voltage drops that can happen in cables and connections.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 10-20-2009, 06:46 PM   #8
Mike W
Mike W's Avatar
Thanks to all that have replied. I used to have a optima battery and it went bad. I put a conventional marine battery in. I have a timing dial back controller in the car. When i dial it back it still has the problem. I have disconnected the neautral switch, and the starter is wired directly to the starter.
When the car starts to turn over its fine til it "hits" then its like it takes everything to turn it over. Turn the ignition off and it will turn over great. I have not checked the volts at the MSD at start.
Mike
Old 10-20-2009, 07:46 PM   #9
Verify that your timing mark and pointer are correct. Also, again, test your starter, your battery, and check your cables.
Old 10-21-2009, 06:18 AM   #10
buzzinhalfdozen
Again sounds like too much timing lead. Try using a volt meter hooked to battery while cranking, you should have at least 11 volts while cranking. You still could be having an ign. timing issue even with the timing controller, I would verify the timing while cranking just for a quick test. Also verifying the pointer is accurate, as mentioned earlier. If as you say it turns over normally with Ign, off then the only difference with Ign. on is stater pushing against Comp. ie spark. Usually the simpelist things are the problem chaeck the basics first. Joe
