Old 09-29-2009, 11:32 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Rod Bolt torque
I bought a super stock engine with a set of Childs and Albert steel rods in it. They look similar to a stock 350 chevy rod. The rod bolt looks like a 3/8 ARP wavelock type bolt. I need the torque spec for this rod. Thanks
Mike Pearson 2485 SS
Old 09-29-2009, 04:50 PM   #2
Default Re: Rod Bolt torque
Mike,
If it is an ARP bolt, you can usually call ARP and get a torque spec and a stretch spec. If you ever start using a stretch gauge, using a torque wrench on rod bolts will make you very nervous.
Old 09-29-2009, 07:14 PM   #3
BillK
Liked 30 Times in 17 Posts
Mike,
Contrary to what Alan said, I have had no luck at all getting ARP to give a torque or stretch spec unless the bolt is one of thier packaged part numbers. As soon as you state that the bolt is in an Eagle ( or C&A, or Scat) rod, they tell you to call the manufacturer. I am under the impression that different manufacturers use the same bolt with different torque specs, and this has been the case several times.
I would call C&A and ask them to be sure.
Bill Koustenis
BillK is offline   Reply With Quote
Old 09-29-2009, 07:48 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
C&A is out of business. Try recalling ARP and crying on their shoulder.
Old 09-29-2009, 08:02 PM   #5
ARP will normally give you a spec IF the original manufacturer of the rod gives one, ARP will have it. If the original manufacturer of the rod does not give a spec (for example, Eagle does not give a stretch spec on some of the SIR rods) then ARP will not have the spec to give.
If ARP does not have it, then you might try a vendor who used to sell C&A products. They may have an old catalog. Normally I save those. I also save the spec sheet on parts, but I don't have anything on C&A rods.
If you do not know what they were originally torqued or stretched to, I strongly suggest that whatever spec you decide to use, you torque them up in a vise outside the engine first, and have them checked for size and roundness, just to make sure you don't create a problem.
Old 09-29-2009, 08:19 PM   #6
Bub Whitaker
Alan... your a wise man...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 09-29-2009, 09:13 PM   #7
Bub, then why ain't I rich?
Old 09-29-2009, 10:00 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
http://www.arp-bolts.com/Catalog/Cat...talog_0024.pdf
ARP on line. Page 24, 25, 26 gives bolt torque specs.
Also at the top of page 33 it gives the procedure for calling ARP TECH and the tech line numbers of some rod mfg's that use ARP fasteners.
http://www.arp-bolts.com/FAQ/TorqueStretch.html
If they are old and you don't know their torque history it might be safe to change them.
It's just a thought, but someone else could have used the wrong torque spec in their life cycle. ... ??
Adger Smith (Former SS)
Old 09-29-2009, 10:01 PM   #9
treessavoy
Liked 4 Times in 4 Posts
Cause you got addicted to drag racing and you didn't start with $3 million.
JimR
Jim Rountree
Old 09-30-2009, 05:33 PM   #10
Bub Whitaker
What JimR said.. we have an addiction / passion to do what we do, we are smart, have common sense, and the ability to direct others on how to do this stuff,... unfortunatelly, they don't teach this at college, so we cant pay for a degree so we can charge for all the hours we give free info for the knowledge we have aquired over the years by bumbeling thru life building engines and learning from our mistakes and failures...sorry for rambling Alan, thats why we ain't rich... I'm gonna get a 900 number!
And Adger, I haven't forgotton about you
Bub Whitaker
