Old 09-20-2009, 04:55 PM   #1
69camz28
Default Cal Tracs Springs
Hi guys. My name is Jeff, I am new to the forum. I was hoping someone could help me out a little with a few questions I have. I have a 69 Camaro - I am trying to set the suspension up like a Stock Eliminator Camaro ( I don't run in the class). I have a factory front suspension - A-arms are stock w/ polygraphite bushings, factory springs with 1 coil cut, no sway bar, and Cal Tracs shocks. In the rear I had Cal Tracs bars with multi-leafs and Rancho 9way shocks. With this set up I ran a best of 10.90 @ 121mph, best of 1.46 60ft off the footbrake and a 275/60/15 MT Drag Radial.
I recently purchased the Cal Tracs split leaf mono, and I had some quesions. The springs appear to have moved the tire forward slightly in my rear wheel wheel, maybe by a 1/4 inch or less. The car also sits slightly lower than it did....Have any of you had an issue like this? Also, what is the largest tire I can run w/o a minitub? Any front end suspension tricks you could share? Sorry for the long post, was just hoping someone could steer me in the right direction.
Thanks,
Jeff
69camz28 is offline   Reply With Quote
Old 09-20-2009, 06:55 PM   #2
SmallBlockNova
SmallBlockNova's Avatar
Send a message via AIM to SmallBlockNova
Default Re: Cal Tracs Springs
Low friction bushings and a lot of travel...
SmallBlockNova is offline   Reply With Quote
Old 09-20-2009, 08:45 PM   #3
69camz28
Thanks for the reply - can you explain hat exactly you mean by 'a lot of travel'?
Old 09-21-2009, 06:12 PM   #4
SmallBlockNova
The distance the nose of your car is able to move upward until the front wheels come off the ground...Crucial in a small tire/low power car that you're trying to get to wheelstand.
Old 09-21-2009, 07:19 PM   #5
69camz28
Thanks for the info....Any suggestions other than the bushings?
Old 09-22-2009, 12:47 AM   #6
Jeff Lee
Jeff Lee's Avatar
Sitting lower may be a good thing; it was for me. Calvert will work with you on the ride height. It involves replacing the rear portion of the spring.
One thing often overlooked by those not running the Stock class but wishing to emulate a Stocker in suspension and leave characteristics is the fact many of these "hard leaving, wheelie poppin' vehicles" have a LOT of ballast in the rear. This is done to make the class minimum weight and / or to gain traction.
Jeff Lee 7494 D/S '70 AMX
Old 09-22-2009, 09:03 AM   #7
69camz28
Has anyone else had an issue with the new springs moving the rear tires forward in the wheelwell?
Old 10-06-2009, 08:10 PM   #8
69camz28
Bump
Old 10-07-2009, 12:39 AM   #9
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
My springs did move the tire forward slightly but my car was already cut to allow a 30in tall tire. I run a radial slick so there is no worries about tire growth. I ordered my springs +1 on the ride height that way when they broke in and sagged a bit there would be no issue with the car sitting too low. Buddy with the nova on the bumper that was talking about front end travel is absolutly right. Remove the upper bump stops and make sure to have some good lowers. I have gone through 3 sets this year because my car stands right up but doesnt have the power to set the nose down easy.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-09-2009, 01:09 PM   #10
denny harvey
they moved mine forward also.stock wheelwells and stock height split monos, run a 29x 10 m/t on 5.5 bs 10 inch rim..
denny harvey is offline   Reply With Quote
