Old 09-03-2009, 01:02 PM   #11
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: Tie Down Techniques
Originally Posted by rodrocket View Post
i will be strapping mine down with straps around the front tyres & cross over the tie straps in the rear to stop the car moveing sideways in the trailer
now if i can find some of them inflatable chassis stabilizers cheap to slide under the rear i will be set
regards
rod
Having anything,whether it's a stabilizer,block of wood etc. in the front and jack stands or what ever on the rear is the key to stopping up and down movement.Tie downs alone will not restrict up and down movement.I think Einstein or Billy Nees said that.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-03-2009, 01:51 PM   #12
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
ED You are Scaring me now
Bob Bender 144 O/SA
Old 09-03-2009, 03:22 PM   #13
partsbob67
Liked 79 Times in 11 Posts
i use frame hooks that i got from truck tow. they hook into the frame at the factory tie down points, keeps the bouncing up and down at a minimum.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 09-03-2009, 03:33 PM   #14
Ed Fernandez
The way I tie it down doesn't drop the suspension.So the springs are at pretty much at static height front and rear.
Bob,sit down loosen the top button on your shirt and have a tall one.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-03-2009, 03:35 PM   #15
treessavoy
Liked 4 Times in 4 Posts
I found a method to keep the car from moving while in transit.
I put the car in the trailer, close the ramp and fill the trailer with expanding foam until it runs out the side door, nothing moves while you're traveling but it's a b**ch to get the car out!
Don't try this at home.
Jim R
Jim Rountree
