Liked 983 Times in 198 Posts
When going to the after market front disc brakes is there a all aluminum master cylinder that will work instead of the plastic aluminum one that the companies sell?If so what does it come on.thanks
Are there any regular automotive all aluminum ones that will work ok?
Liked 138 Times in 51 Posts
OEM Chrysler applications are popular that have the aluminum body and plastic resevoir.
I have a OEM manual disc/drum application from a late '70's Aspen/Volare on my OEM manual disc/drum Dart Sport. But I was considering doing to a larger truck version if I switch to aftermarket front discs. I don't have any part #'s handy because I'm at work.
LOCOMOTION Racing |
Liked 333 Times in 180 Posts
--Lyn -----many of the late model GM cars specifically the corvettes utilize an all aluminum master cylinder and have a metal(steel) cap held in place with the old style snap ring setup--- they are very light only about 5 pounds each--- do not know how much trouble it would be to graft it onto your car tho---probably just hafta fabricate a plate to bolt onto your firewall and then make the appropriate rod to go from the B pedal to the cylinder--- should not be to difficult to do----- Comp 387
Liked 3 Times in 1 Post
Banned
Just dont forget to secure the "PushRod" the way Lamb has..been a couple of incidents ..Biondo..Woodro(i think) etc.
Liked 797 Times in 165 Posts
mid early 80's S10 master with manual brakes. I have bought 3 of them and never used a proportioning valve. When you buy one, sometimes they come thru steel instead of aluminum, so check the box before you leave the store. Never had a leak issue.
Dave
Dave Casey 1330 STK |
thanks guys for all the info.
Liked 279 Times in 68 Posts
Lynn, I use a strange MC with no problems. It's been on my car for about 10 years. I think it's a 1" bore. Some of the mid 70's corvette MC will work with just front discs.
Greg
Greg Hill 4171 STK |
Liked 2 Times in 2 Posts
Disc/drum combo?
Tod Lane Swartz & Lane 66 Nova Swartz & Lane 79 H/CM Trans Am |
