Liked 529 Times in 36 Posts
I was wanting the contact information for the adjustable brake pressure launch control with the brake pressure gauge.
Thanks Darcy Clarke Stk 6254 A/SA, F/SA, G/SA, H/SA |
I use a GEMS adjustable pressure switch. They are available thru industrial supply houses. Also, try E-Bay. I do not remember the model #, only that it is a 1/8 npt fitting. Also, it cost about $40-50 dollars. Hope this helps!
Banned
adjustable delay presure switches? Gee, just when I thought I left that stuff behind when I went Stock Eliminator racing .... guess not.
Maybe we should add adjustable pressure buttons for the brake pedal too? Maybe just a small delay box....won't hurt anything, right? I thought that stuff was for the Delay Box guys, guess not. That's pretty disappointing actually. Jok |
Jok,
This is not a delay switch it works off of brake pressure, with no difference from a brake pedal switch and is legal and widely used. If these are illegal then brake pressure gauges should be as well. Darcy Clarke STK 6254 A/SA. F/SA, G/SA. H/SA |
Liked 4 Times in 2 Posts
Darcy.. give me a call 425 941-8765 i know someone who has what your looking for...are you going to Montana??? Jim Storms
Liked 5 Times in 5 Posts
Can someone post the part number for the Gems adjustable pressure switch that everyone is using please? or any other brands that work. Thank-you.
6535 stk 81 Malibu K/SA |
Darcy you have PM
Ed M. 6810 H/SA |
Thanks for all the help guys!!
Jim I would like to go to Montana but I am not sure yet, I will let you know. Darcy Clarke 6254 STK A/SA, F/SA, G/SA, H/SA |
All you guys CRIED about the finger button? Give me a f ing break!
No prep is king |
Liked 2,487 Times in 698 Posts
No two-steps, no switches.......JUST brake and gas petals on All our stuff!
