Liked 8 Times in 7 Posts
ok, wondering if it's ok with nhra to run a hydralic clutch (T.O. bearing) where the was a mechanical linkage....
it sure would make my life easier ![]() |
Liked 1,778 Times in 404 Posts
I do not think that is legal. You really need to write to Bachelder or Gracia and get an answer in writing, and keep it with you.
Alan Roehrich 212A G/S |
Liked 520 Times in 132 Posts
I had a hydraulic set up in my car at first. Yes in IHRA. No in NHRA. That was 3 years ago. I run mechanical now.
No in NHRA. Same with electro-magnetic clutch release...not even in superstock.
Jeff Lee 7494 D/S '70 AMX |
Liked 8 Times in 5 Posts
If the car / truck originally had a hydraulic clutch system its legal.
True, but the original question stated he had a mechanical and wanted to change to hydraulic.
Liked 880 Times in 311 Posts
What about GT conversions? I took a quick scan of the rule book and nothing jumped out. Does the clutch system go with the car or the engine combination? You know most of these newer model conversions had Hyd clutches & some are only automatic.
Which way does it go?
Adger Smith (Former SS) |
The original poster is building a stocker. But on the GT question, I would ask why would you want a hydraulic system? They seem to pose quite a few problems in releasing the clutch at an acceptable rate, causing problems in engagement (based on what I have read and heard).
Todays clutches offer very little resistance; you can push the pedal in with your fingers if running a competitive unit. Even those units adjusted to a high base pressure are nothing like the old "3400+ pound" pressure plates which made your left leg shake at the stop light! If space is a concern, GT allows quite a bit of floor / firewall rework. Is there enough room on a small GT car for all the z-bar and other linkage?
Liked 442 Times in 112 Posts
travis said NO when i asked about the witch doctor, damn thing has a reverse "pull" cable clutch that some GM engineer is still laughing about.
captain jack
Jack McCarthy 3609 STK "the Captain" |
now that we've decided that hydralic is out, can i modify the mechanical linkage w/ heim joints?
