Old 07-29-2009, 11:58 AM   #11
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: "G" Body suspention tips ?
Most of the major chassis shop's such as Strange, Moser, Mark Williams make a complete bolt in 12 bolt g body car.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 07-29-2009, 12:02 PM   #12
Greg Barsamian
Liked 427 Times in 97 Posts
I think he can help you!
http://www.dragracecentral.com/DRCPh...r2009#indextop
Old 07-29-2009, 07:32 PM   #13
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
The location point on mine are moved up... also don't forget to air-bag the thing!
Old 07-29-2009, 09:51 PM   #14
CJohnson
CJohnson's Avatar
Originally Posted by Bob Gullett View Post
I guess the question is, is the 12 bolt modified to fit the G-body? Are the upper ears located in the proper angle to the upper control arms? If it was an "A" body 12 bolt, the upper control arm attachments are not in the proper location. You probably can force the control arms to fit but it will seriously bind. Post a little more info on the 12 bolt install.
The upper ears on the 12 bolt are way lower then the ears on the 7.5" I had. With the stock upper control arms the one on the right seemed to fit alot better then the one on the left. do you think putting in adjustable upper control arms will be enough or do i have to get the ears on the 12 bolt raised. or do you know of any kit to raise the upper ears ?
Thanks for your help,
Craig - C693
CJohnson is offline   Reply With Quote
Old 07-29-2009, 10:09 PM   #15
Liked 5,134 Times in 1,958 Posts
Craig - C693
When you raise the rear up on those cars for tire clearance, the projected instant center goes out of this world.
Do a search for no hops bars. Several companies offer them. Get the proper upper control arms. I'll have to assume that you've got the wrong lower ones,too.
Don't forget some good shocks and air lift bags.
That'll stop the bouncing.
Old 07-29-2009, 10:21 PM   #16
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Craig, shoot me an e-mail.
dave6888@shaw.ca
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 07-29-2009, 10:36 PM   #17
CJohnson
CJohnson's Avatar
Thanks for the info Mark, I have ordered these lower arm relocation mounts ive heard good things from these. as you do not need to have the adjustable lowers
http://www.gnetworks.com/v4/go.gnf?s...&currentPage=1
And also wouldnt a good set of cargo coils do the same job as a set of drag bags ?
Thanks,
Craig
Old 07-29-2009, 10:39 PM   #18
CJohnson
CJohnson's Avatar
dave6888@shaw.ca
E-mailed
Old 07-29-2009, 11:17 PM   #19
Tom Moock
Liked 10 Times in 6 Posts
CJohnson, looking at picture of your car, you want the body to lift in rear away from the rear tire when you leave the starting line, no hop bars change the control arms angle to make rear lift and plant the tires, also no adjustable lower control arms in stock. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 07-30-2009, 12:07 AM   #20
CJohnson
CJohnson's Avatar
Thanks Tom, do you know if you are allowed the adjustable mounts for the lower control arms in stock ?
I finally took a look at those no hop bars, and i understand how they work now.
