I hear talk of superstock racers that have to change valve springs after 10 runs, is this for real? I know they run nearly an inch of lift, and almost 9000 rpms, but nascar runs 9000 for 500 miles. THOUGHTS.
Banned
NASCAR Cams are smooth cams and no where the jerk a good Drag Race cam has.
Liked 53 Times in 13 Posts
It depend on what class you're running. Since I use the "441" casting SBC head i'm limited on how big my valve spring pocket can be cut for the 1.64 spring without hitting a water jacket, so I use the 1.55 spring and yes you get only 10-15 runs out of a set, and it could go either way depend on how high you rev your motor. Luke
Liked 110 Times in 29 Posts
I was told the hot set-up in valve springs for Super Stock are PAC . Used on a lot of Pro Stockers and Comp engines. Suppose to have long life. Check them out at racingsprings.com.
I really like the 1.5" dia PACs. Got mine from Patterson Racing Engines.
Ed Wright 4156 SS/JA |
Liked 19 Times in 8 Posts
It's like anything "You get what you pay for" Comp #26082 should last over a season
Joe Schweigert 751 SS |
Liked 351 Times in 120 Posts
I use 947 comp springs 1.85 installed ht 400 lbs on the seat will set in about 380 to 360 will last me 2 years or about 300 plus runs on my 283 520 head. I shift at 9000 same in the lights. Camshaft and rockers ratio have a lot to do with it along with harmonics. Tom
Tom Meyer 5240 SS Stock ??? |
I agree. I used Comps #947 springs and they lasted the season.
Jesse Knapp 4899 STK, SS |
