Liked 5 Times in 3 Posts
Does anyone other than clevite make a main bearing to put a 283 crank in a 350 block?
Clevite only has one at standard and standard cranks are getting few and far between. |
here is bearing spacers
http://www.raceeng.com/p-7689-bearin...27-to-350.aspx |
Doesn't King still make spacer bearings? Thicker bearings, no spacers needed.
Ed Wright 4156 SS/JA |
I called king today and they no longer have anything for large to small journal conversion. I dont think I like the idea of spacers either. My current engine has clevite mains and is currently fine but for the future maybe an aftermarket 3.0 stroke crank or go back to a 283 block.
#5 | |
Liked 780 Times in 194 Posts
Liked 544 Times in 213 Posts
I agree with Dwight......I have used spacers that we made from std. bearings in a 400 block to install a 350 crank for a 377's. We line bored the bearings to size. I went thru the trouble of drilling thru the bearing spacer into the main saddle and tapping the hole for a machine screw. I used countersunk headed screws and ground them down to be sure they sat below the surface. Never had a problem using those for myself or my buddy and he really rpm'ed his stuff!! His motor generally saw 8200 on every run.....
Guest
Posts: n/a
No problems with spacer bearings here either. Been using them for about 15 years with a 327 crank in a 350 poured block. Engine turns between 9500-10,000 rpm thru the 1/4. I use the ones from Race Engineering made fron ACL bearings.
SCOTT
Do you install the spacers directly in the block as is? Sounds like I should buy a set and not worry about it. |
Guest
Posts: n/a
Pretty much as they come. I do check the slots where the bearing lock tang sits in the spacer. I sometime have to file the slot a little for the bearing to fit the way I like. I torque the main caps in place with the spacer bearings just to double check the bore to make sure there is not a problem. I then install the bearings and check my crank clearance. I've used several sets without any problems.
Usually you have to have a line hone done to the spacers, then they stay with that block in order of placement, makes future freshening easier.
Patterson sells them too....usually in stock |
