Old 05-29-2009, 06:29 PM   #11
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Single wheelie bar
it "may" be that the spring is captured on each end so that the spring is stretched or expanded as the lower bar increases in length. Looks to me like the upper bars would swing up and the lower bar has a telescoping section that stretches the spring. More details would be a good thing. I also would like to know the builder.
Larry Woodfin 471W
Old 05-29-2009, 07:10 PM   #12
Doug Estabrook
Here is the car it's installed on. So, if I understand, the only advantage to the single bar is in case of breakage?
Doug
Doug Estabrook is offline   Reply With Quote
Old 11-13-2009, 01:03 PM   #13
JOE FIANO STK1267
Question Re: Single wheelie bar
where can i order one of these wheelie bars? that is pictured on the nova tied into rear end call me 585-507-0825 joe fiano
JOE FIANO 1267 STK
Last edited by JOE FIANO STK1267; 11-13-2009 at 01:05 PM. Reason: wheelie bar on nova
JOE FIANO STK1267 is offline   Reply With Quote
Old 11-13-2009, 01:37 PM   #14
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Ken Keir Race Cars Components. 7605 Ginger Ln Owings, MD 20736-3104 301-855-4988
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is offline   Reply With Quote
Old 11-13-2009, 05:00 PM   #15
Signman
Liked 269 Times in 99 Posts
Have seen the car and the wheelie bar. It is an aluminum plate that uses cover mounting studs. It is sandwiched between the housing and cover presumably with longer studs. No additional mounting or attachment. Very cool.
Old 11-13-2009, 08:04 PM   #16
larrylomascolo
Liked 66 Times in 29 Posts
Troy Henderson a/s also has built a single wheelie bar as mentioned in a previous post here.
Old 11-13-2009, 08:17 PM   #17
Ed Wright
Ed Wright's Avatar
I'm seeing more singles all the time. I put a set of regular bars on mine, and about the second time I tested with them it got up on them too hard at Tulsa, and I about took out the tree. I took them back off, until I can figure out how to use them. Been looking hard at going to a single bar. Slate Cummings has a single bar on his LS1 stocker. Looks like a good deal to me.
Ed Wright 4156 SS/JA
Old 11-13-2009, 09:01 PM   #18
J Kuchel
Banned
I see them used on small tire stockers mostly but, will they work as well on a big tire car like a super stock or a bracket car?
J Kuchel is offline   Reply With Quote
Old 11-13-2009, 09:16 PM   #19
Jimi B
With the single wheelie bar, there is less roll resistance. Also, I would imagine that it takes possible unnecessary adjustments out of the equation, making it easier to tune the suspension and probably adding to consistency.
Jimi B is offline   Reply With Quote
Old 11-13-2009, 11:17 PM   #20
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
The one that Ken Keir makes is probly the neatest set up for a 12 bolt. If i remember right it sandwhiches a plate between the housing and rear cover so when working on the gear its completely out of the way. He was advertising it at the MIR race this fall but cant remember how much it was. Hell of a nice guy to talk to as well. Been building comp cars longer then ive been alive, very good name. Dave F posted his info a page back.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
