Old 05-19-2009, 06:53 PM   #11
Z28-69
Default Re: Hesitation after landing of wheel stand
Originally Posted by Adger Smith View Post
If you don't suspect fuel then it has to be ignition. I Like the idea it could be battery plates bouncing around & shorting out. Put a Battery Volt gauge where you can read it during the landing. If it doesn't drop then start looking for grounds or connections pulling apart or anything that could be causing high resistance during the crash back to earth. I found a rotor/cap in my V-6 causing problems similar to yours. The cap fit too loose & was shaking around causing spark scatter. Look for the simple things. It will always be the last thing you look at that fixes the problem... :~)
I like what you said Adger, :-) Thats about it too. I just might make a long list of things to check and then go to the LAST ONE! Isn't that how it goes. We hope to figure it out on Sat. Thanks for the replys guys! Really appreciate it. Eric
Z28-69 is offline   Reply With Quote
Old 05-20-2009, 01:27 AM   #12
Jeff Lee
Jeff Lee's Avatar
Is this a Superstocker? If so, another idea to toss around is a wedge carb spacer.
Jeff Lee 7494 D/S '70 AMX
Old 05-20-2009, 10:17 AM   #13
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I had that same problem many years ago. As soon as it came down there was that ever so slight hesitation then it picked up & ran strong to the end. It turned out I needed that wedge plate as Jeff mentioned in the previous post. Probably was starving the secondaries at the top but I did not notice until it landed.
55 Chevy is offline   Reply With Quote
