#11 | |
Liked 1,784 Times in 407 Posts
Alan Roehrich 212A G/S |
#12 | |
Liked 5,109 Times in 1,947 Posts
Thanks for confusing the issue .Now all the 2 speed Tempests and GTO's on Ebay can still claim they have a Powerglide in them. How about Canadian Pontiacs? Transaxle Tempests? Technically a PG, I guess. Hey everybody , Alan is right. Mark is wrong .Got it?
#13 |
Liked 320 Times in 102 Posts
Hey Mark,
And don't forget that the SuperTurbine 300 had a TH400 size output. Bob
#14 | |
30 spline input too, so it takes a 350/400 converter where a PG does not. That was the trick back then. Put a 6 cyl , ST300 converter in a T400 V8 car, and get about 2000-22000 stall.
#15 |
Liked 19 Times in 7 Posts
If all the superstock guys are going to 3 speeds how could a powerglide be a faster trans in stock? You think a stocker motor makes enough tork to recover fast enough on the gear change with a glide? Turbo 350's seem to be the cheapest way to go. And you can't break the damn things...my trans builder built me 3 turbo 350's identical to eachother, one for my 9 second street car and two for my stocker. All stock internals except for the valve body, TCI sprag and some pump work. I can build 3 turbos (non lightweight) and have the same money invested in 1 powerglide. The gearset is what make it more expensive. Just my opinion.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 04-08-2009 at 04:41 PM. |
#16 | |
I didn't confuse anyone any more than you did. You said NEVER. That was not correct. Don't take it so personal. Got it?
#17 | |
#18 | |
I just didn't think that was a good time to muddy the waters with that little known fact. Shoulda known I couldn't slip it by you.
#19 |
Alan and Mark,
Why can't you two get along as well while you're disagreeing with each other on this topic as you each do with others who have different political viewpoints? Play nice.
John Mason 7743 SS |
#20 |
We're getting along fine.
