i have a 68 firebird and i need to know the factory shipping weight.iam running 350/305 hp gm crate what class does this fit in.thanks lorne
#2 | |
Liked 19 Times in 7 Posts
With a 300hp combo your probably going to be in I or J depending on how light you can get it. In I (10lbs) you will weigh 3230 and in J (10.5lbs) you will weigh 3373. If you still have all the interior, stock style multi leaf springs and stock tank or big fuel cell (12gal) like myself you will fit J no problem. I was 3375 at the national event and had to add 25 lbs to make 3400.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Liked 334 Times in 181 Posts
68 f'bird coupe 350 v8 shipping weight is 3222-3300 pounds --Comp 387
