Old 04-02-2007, 10:36 AM   #1
RPinoski1
Default NHRA ACCEPETD AFTER MARKET CRANKSHAFTS
Can anyone guide me to the list of accepted aftermarket cranks?????
"I've never seen a Hearse with a Luggage Rack, You Can't Take it With You" Mike Ness
RPinoski1 is offline   Reply With Quote
Old 04-02-2007, 03:01 PM   #2
SSDiv6
Liked 1,582 Times in 582 Posts
Default
Crower is the only company that has a small block Chevy crank that has been in use for some time. It has a factory part number too.
http://www.crower.com/pdf/173-188.pdf
They are under the "Stock Plus" and "Pure Stock" names.
Old 04-02-2007, 08:41 PM   #3
Jeff Lee
Guest
Posts: n/a
Default
Raw GM crank forgings are shipped directly from
GM?s foundry to Crower. Stock GM part number is
forged into the counterweight. Features include lightening
holes and O.D. trimming that reduces weight
by 4 to 5 lbs under stock. Crower race-prep includes
1⁄8 radii and Crower heat-treat. Thorough magna-flux
inspection, chamfered oil holes, end-to-end index
check and polishing come standard. Crower even
straightens them so you don?t have to. Complete
stock legal engine kits also available.
WEIGHT: 51 lbs (4 to 5 lbs under stock GM weight
This is the "Stock Plus" crankshaft. Why would NHRA allow "lightening
by 4 to 5 lbs under stock"?
Is there a limit to OD trimming? If OD trimming why not all the other mods in the other series (eliminate center CW, profile milling, wing contour, etc.)?
NHRA #7494 SS/H
1970 AMC AMX 390
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
Arizona's BEST Realtor supports racers!
Now celebrating 14 years as a Realtor,
Call me @ 602-418-9797 or JeffLeeAzRealty@Qwest.net
