Old 05-12-2007, 10:17 PM   #1
Stock 5 point 0
Default Question about Mickey Thomspon ET Drag Wheels
I am thinking about buying a set of these for my new stocker I am getting ready to start building. It will be a 89 Mustang. You can only get a 15x8 with a 4.5 back spaceing. Do any of you guys know if this would be the right off set for a mustang. I know a 15x8 Weld wheel is 5.5 back spaceing. If you or any body you know that put these wheels on a 79-93 Mustang let me know if they fit good .Thanks
Stock 5 point 0 is offline   Reply With Quote
Old 05-13-2007, 12:38 AM   #2
Jeff Lee
Guest
Posts: n/a
Default
Did you check with Larry Hodge? (Find his link at the top of the page under "drag wheels" on Racingjunk.com)
He has a much larger selection of backspacings than direct from M/T. I just bought two sets this week. Smokin' deal!
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
Old 05-13-2007, 03:26 AM   #3
Liked 5,121 Times in 1,952 Posts
Default
I assume you are converting to 5 lug wheels? The 4 lugs are not available yet from Mickey.
Most Mustang wheels don't have enough negative offset because of the original horizontal (quad) shocks.
Blue Streak Promotions
Old 05-13-2007, 09:33 AM   #4
DIAPERMAN
Liked 21 Times in 6 Posts
Default
call Larry Hodge he will be able to give you all the info you need 217 433 3060
WWW.ENGINEDIAPERS.COM
DIAPERMAN is offline   Reply With Quote
