Old 08-21-2008, 04:03 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Fiberglass Leaf Springs w/ cal tracs?
Anyone ever try Fiberglass Leaf Springs with cal tracs?
MEXJOE is offline   Reply With Quote
Old 08-21-2008, 09:05 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Fiberglass Leaf Springs w/ cal tracs?
i think you would break the spring where the roller makes contact. maybe if you welded a wide flat plate to the roller pivot to widen the loaded area you could get away with it.
Mark Markow is offline   Reply With Quote
Old 08-21-2008, 09:24 PM   #3
dahkahuna
Liked 5 Times in 3 Posts
In 1992 I was lucky enough to be able to run my 1969 camaro e/sa at indy, my first indy.during the event of course while talking with and looking at so many top flite stockers, the one guy i went to see was dave lebrun. The one thing i noticed was that he had adapted a corvette late model fiberglas spring on his car. That stuck in my memory as a very ingenious idea, so when i returned home i started to research how to duplicate such a good idea. At that time calvert bars were not even designed yet. I first installed a fiberglas spring on my car the next year and design traction bars that were similar to the old traction master type bars with clevis .ends so that it was adjustible, the fiberglas spring held up just fine and the advantage of removing tri-city spring that weighed 90 lbs. Sprug wt. And putting it in a weight box help 60 ft. Times ,especially when the radials came out that same year by goodyear.my custom designed traction bar eventually became the forunner of the calvert design with a very differint side plate configuration to the one that calvert now produces.i now use calvert bars ,they are very good traction bars and a very quality product I highly recommend them when you use a fiberglas spring . .
dahkahuna is offline   Reply With Quote
Old 08-21-2008, 09:53 PM   #4
Matt Welker
Liked 77 Times in 15 Posts
One can learn a lot from Dave, my car has fiberglass springs as well.......
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is online now   Reply With Quote
Old 08-22-2008, 12:33 PM   #5
Elan Imseis
Elan Imseis's Avatar
So where can you get fiberglass leaf springs for a 68 Camaro?
Elan Imseis is offline   Reply With Quote
Old 08-22-2008, 12:50 PM   #6
MEXJOE
MEXJOE's Avatar
Thumbs up Re: Fiberglass Leaf Springs w/ cal tracs?
THANK YOU!
I'm going to try it
Old 08-22-2008, 11:16 PM   #7
Jeff Lee
Jeff Lee's Avatar
I've heard some of the Chevy Astro vans have a carbon-fibre leaf spring that can be adapted to your typical GM muscle car. That's a junk yard item!
Jeff Lee 7494 D/S '70 AMX
Old 08-23-2008, 08:27 PM   #8
dahkahuna
I recently got mine from flex-form real nice guy get the 225 lb. springs tell him you are using calvert bars ,he will help you with the solid aluminum bushings, Calvert also has solid bushings I also originally bought a set from VETTE BRAKE in Florida although Im not sure they are in bussiness still. I Hope this helps you .
Old 08-26-2008, 11:57 PM   #9
67camaroracer
67camaroracer's Avatar
I run the springs from vette brakes and they work well. Are the springs from the other company listed as good. I may need to replace these some day.
67camaroracer is offline   Reply With Quote
Old 08-28-2008, 08:05 AM   #10
dahkahuna
flex-a-form and vette products springs are identical, I think flex-a-form made the springs for vette brakes.
