Old 08-05-2008, 04:29 PM   #1
rpmrcn7616
Default building a 71 nova stocker?
i curnetly have a 1971 nova that i curntly bracket race looking to turn it into a stocker wanted to get some ideas on a whats a good engine and trans and rear end combo with out breaking the bank and im not planing on seting the world record with it just wana know what are some classes i can make it any inpt would be nice curently has a 10 bolt rear and with a spool 4:56 gears with a mutli leaf springs with compition engenering slide a links (will this rear end work ) also can i clam it as a 68-72 nova?
rpmrcn7616 is offline   Reply With Quote
Old 08-05-2008, 06:55 PM   #2
Liked 1,826 Times in 414 Posts
Default Re: building a 71 nova stocker?
Yep. Build it as a 69, with a 12 bolt and CalTracs, and buy the stuff Brian Oakes has for sale.
Old 08-05-2008, 07:20 PM   #3
Bobby Lundholm
Liked 126 Times in 49 Posts
I ran the 71 motor in my nova for about 2 years. The best I went in H/SA was 11.37 with over a 100 runs on the motor. Woodro Josey built the motor and it was really strong. It's a real good combo I think it's currently rated at 270/274. I have a set of the heads and intake for that combo forsale for $125 if you are interested.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 08-05-2008, 07:32 PM   #4
Bill Belden
Bill Belden's Avatar
Auto is 283hp stick is 274hp
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 08-05-2008, 09:27 PM   #5
rpmrcn7616
was that the 350 or the 307 and did it fit into i or g what trans and rear end did you use
Old 08-05-2008, 09:38 PM   #6
Joe DeMarzo
Liked 113 Times in 9 Posts
Bill the 350 in 71 and 72 is only rated 278, I do not believe a 307 came in 1971 Nova
Joe DeMarzo 1317 STK
Old 08-05-2008, 10:25 PM   #7
Bobby Lundholm
It was a 350 in 71' used a turbo 350 with 5.13 gears.
If I remember correctly it's a G,H,I combo.
Old 08-05-2008, 10:29 PM   #8
FED 387
Liked 333 Times in 180 Posts
71 Nova 200 HP 307 cu in available both 2 & 4 door--Comp 387
Old 08-05-2008, 11:05 PM   #9
WCW
The 72 307 is only at 175 in the nova.......clarence
WCW is offline   Reply With Quote
Old 08-06-2008, 07:25 AM   #10
Billy Nees
Liked 7,732 Times in 1,739 Posts
Unless you're "indepedently wealthy" or into self inflicted pain, I wouldn't do a big block combo right now. I am trying to get a 307 car to work and even at 175 hp the carb is just too small. The 6 cyls. are cheap and fast but too inconsistant. If I were starting from scratch and had a nice body with a 10 bolt in it I would do a 70 350 2V @ 230 hp. The specs on that combo are so screwed up to the good that I'm suprised that there is only one running (Kinash). Check it out.
Billy Nees 1188 STK, SS
