Old 05-02-2025, 09:50 AM   #1
BRETV
Liked 776 Times in 199 Posts
Default VP C-11 Compression
What's the highest compression ratio you guys have seen that C-11 is still good for?
Bret Velde
2003 I/SA
BRETV is offline   Reply With Quote
Old 05-02-2025, 01:18 PM   #2
GTX JOHN
Default Re: VP C-11 Compression
We routinely run it at 11.8 to 1.
John Irving
741 Stock
741 Super Stock
Old 05-05-2025, 09:56 AM   #3
Robin Lawrence
Sponsor
Liked 716 Times in 120 Posts
I have been running the C11 in my Coyote for years. Original combo was a 2012 325 HP deal. That RPM was limited by the intake and throttle body so it was out of power by 7500 RPM.
When I switched to the 2013 350 Combo I kept running the C11. The CR calculates to 14.03 to 1. Still works well but with less timing. Since this engine RPM's over 9000 I have been testing C14 ion the dyno. Seems to work well and wants different Air Fuel ratio and Timing. (more fuel and more timing). Engine is still on dyno for some more testing as well as a little C25. Not gonna pay the money to run C25 but want to see if there is a difference and if the tune needs to change..........if I ever need to run the C25.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 05-05-2025, 11:23 AM   #4
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Robin
Hi Robin,
Been telling Fogle for years the C-25 was a waste of money. During his last freshen we backed to backed C-12 against C-25. L-98 10:1 motor. All we did was pour it in. No other changes. Picked up 3-4 from the start of pull to 8800. I accept defeat. LOL
Jeff Niceswanger 3740 SS
Old 05-05-2025, 12:11 PM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Originally Posted by Jeff Niceswanger View Post
Hi Robin,
Did you try c11 to c25 on dyno ?
Old 05-05-2025, 10:01 PM   #6
Jeff Niceswanger
Did not..
Old 05-06-2025, 08:02 AM   #7
GUMP
Liked 2,361 Times in 558 Posts
I would bet that the C11 would be better than the C12 on that L-98.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 05-06-2025, 12:59 PM   #8
Glenn Briglio
About 6-7 hp better
