#61 |
Liked 5,137 Times in 1,960 Posts
Yes , when racers tell you you should have the converter cut open and cleaned and inspected , they are certainly correct.
However, you can take a chance,by not doing so, in your situation. Most of the long term fine debris in a converter, ends up around the overlap, where the weld seam is, due to centrifugal force . That's probably not going anywhere. It there's anything recent in there, it's possible to flush it up. First thing you should do is set it on the bench and place a clear plastic tube all the way in and down to the pilot area. Siphon the remaining ATF out over the edge of the bench. Then, if you have a parts cleaner, with fresh, clean solvent in it, place the tube all the way in and let it run for a while. If you don't have that available, then pick up a gallon of mineral spirits and pour in as much as you can. Place a T350 input shaft in the unit and spin the turbine back and forth to stir up the fluid. Then quickly dump what you can into a clean pan. Finish by siphoning out the remainder of the solvent. Then blow it out thoroughly , best you can . If you haven't found a big chunks by now, you'll probably be okay, assuming the bearings and thrust washers aren't falling apart. Disclaimer...You heard this from my ghost writer. Not from me.
#62 | |
Liked 1,236 Times in 350 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#63 | |
Liked 974 Times in 310 Posts
#64 |
Liked 210 Times in 91 Posts
I agree with Glenn. I think it is a little easier on the converter and trans if you mat the gas in high gear from a 10-15 MPH roll instead of stopped. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#65 | |
#66 |
Liked 133 Times in 76 Posts
At the least flush out or replace the cooler, that is where debris can be found. Buy a couple of neodymium magnets and put them in the pan in the future.
#68 |
Yup, and looks like their cover.They aren't really billet, but cast and machined.
#69 |
Liked 26 Times in 13 Posts
It looks like you are in Charlotte, Ultimate Converter Concepts is right up the road in Cornelius, NC. 704 892 6880
Bill Harris ex 2172 STK ex 2272 S/S |
#70 | |
Liked 24 Times in 11 Posts
