Old 02-02-2024, 05:15 PM   #11
L.Fite
Liked 497 Times in 243 Posts
Default Re: GM sportsman Bow Tie sbc block question
Two piece...
L.Fite is offline   Reply With Quote
Old 02-02-2024, 06:58 PM   #12
prostockpete1
Liked 90 Times in 52 Posts
L.Fite .. now confused that you think its a 2 piece where as Mike P thinks its a 1 piece .. so a 1 or 2 piece would have different hole dia on the rear flange if one was ordering a new flywheel or flexplate ?
prostockpete1 is offline   Reply With Quote
Old 02-02-2024, 07:08 PM   #13
pmrphil
Liked 347 Times in 151 Posts
Yes, two piece and one piece flexplates are different. Yours must be a two piece (as Eman said) a one piece can NOT have a flange on it.
Phil Molski
PMR Performance
S/C 1623
Old 02-02-2024, 07:46 PM   #14
prostockpete1
so there must be two hole diameters to locate the center to mount the 6 bolts
Old 02-03-2024, 09:34 AM   #15
pmrphil
Yes, that is correct.
Phil Molski
PMR Performance
S/C 1623
Old 02-03-2024, 12:57 PM   #16
L.Fite
Sorry...
If the crank has a flange it is two piece like the old BBC/SBC...
One piece has no flange, per se... like LS...
Old 02-03-2024, 01:04 PM   #17
L.Fite
Two piece main seal chevy cranks
(play the video to see actual picture)
These are picture of two piece crank flanges
Old 02-03-2024, 01:13 PM   #18
L.Fite
One piece... No flange...
Hope this helps.
Old 02-03-2024, 02:39 PM   #19
prostockpete1
What I have in those crank flange photos is like 327 small j & the 350 photo ..so must be 2 piece ⁹
Old 02-04-2024, 02:45 PM   #20
Mike Pearson
Mike Pearson's Avatar
Liked 1,925 Times in 579 Posts
In the original post the question was whether the block was 1 or 2 piece. That is how I answered the question. He did not ask about the crank. If the crank has a flange like the older style then it is a 2 piece seal and will take the older style flex plate.
Mike Pearson 2485 SS
