Old 03-27-2023, 01:26 PM   #11
motoheada1
Liked 4 Times in 2 Posts
Default Re: Metric 200 Builders?
He's all the way out on the Left coast, but fellow stock class racer Leo Glasbrenner owns Remac Transmission and his collection of Wally's speak for themselves.
Chuck
motoheada1 is offline   Reply With Quote
Old 03-27-2023, 02:34 PM   #12
hevychevy
Liked 2 Times in 2 Posts
I have a brand new McClay that’s only been used for a mock up. Electric 1-2 auto shift, 2.84 first gear and Turbo input shaft.
hevychevy is offline   Reply With Quote
Old 03-28-2023, 02:45 PM   #13
KennyAnderson
Liked 357 Times in 119 Posts
I have the builder part figured out....I just need someone to tell me how to get them to STOP LEAKING!!!
Trailer floor is well lubricated! LOL!!
KennyAnderson is offline   Reply With Quote
Old 03-28-2023, 05:19 PM   #14
MR DERBY CITY
Liked 7,938 Times in 1,519 Posts
Kenny, a Fel pro pan gasket is a good start..
Old 03-29-2023, 08:50 AM   #15
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
I had to drill out and helicoil most of the threads on the bolts and put pipe sealer on the bolts too, then sprayed the gasket with copper gasket seal spray and cemented it on to the pan. Also recheck and redo the o ring and thread seal on the plunger detent for the auto 1-2 if you have one.
Leak free now
Old 03-29-2023, 12:16 PM   #16
jmantle
Liked 172 Times in 81 Posts
Do you have an Ultrabell on it? Does it appear to be leaking at the front? Just curious because I just went thru a customers with that problem.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 03-29-2023, 10:28 PM   #17
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
For the leak check the shifter shaft seal,it's above the pan rail.It can fool you in thinking it's the gasket...gsa612
Old 03-30-2023, 11:43 AM   #18
KennyAnderson
Thanks for the replies guys. No Ultra-Bell and I just bought a couple Fel-Pro Gaskets, One in the Nova just got one. I have 3 of these bastiges and they all seem to leak somewhere else. The 1-2 shift adjuster is a big culprit. Each one got some love and that seemed to help.
Old 03-30-2023, 06:39 PM   #19
Fasttrackshooter
Liked 6 Times in 4 Posts
Thumbs up Re: Metric 200 Builders?
Scott McClay the best
Fasttrackshooter is offline   Reply With Quote
