Old 02-20-2023, 04:20 PM   #1
Woodfin
Liked 276 Times in 106 Posts
Default manual trans and clutch quaetion
Racers, for those of you racing a manual trans.
I am considering building and racing in the Nostalgia Modified and Gassers association. This is a new program that is beginning in the North Texas service area. Other areas of the country run similar programs.
It is an index program with break out in place. The specific classes I am considering are C/G on 5.92 index or D/G on 6.09 index. It will be a relatively light weight, back half door car with a 408 LS engine so the performance will be easily attained.
My question, tell me about the clutch and transmission that will give good service life and will be relatively easy to maintain. As of now, to win the event would mean 6 or 7 passes for the day, including time trials.
NOTE: clutchless shifting is allowed.
Old 02-20-2023, 04:51 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: manual trans and clutch quaetion
Following.
I'm looking a the Street roadster classes.
I have a couple G Force 5 speeds I'm going to use.
I am interested in ideas about Clutches.
Larry I'm not sure about the L/S engine platform.
Better double check on that with Kevin Hall and Tony Smith
At one time they wanted me to use iron heads like a purist modified.
I know this is evolving some..
Come on Clutch guys. Input, please.
It will have to be "Easy to Maintain" if this cripple is going to do it.
Adger Smith (Former SS)
Old 02-20-2023, 05:54 PM   #3
Woodfin
Adger, I have already talked with Kevin and the LS engine is OK. He tells me any door car or pick up that is 1979 or older is OK. I like your roadster idea.
Old 02-20-2023, 05:57 PM   #4
Woodfin
Adger, Kevin explained to me that they relaxed the engine requirements in an effort to make it more reasonable to build a car. They are allowing the index to be the governor.
Old 02-20-2023, 06:04 PM   #5
Woodfin
Adger, we did not specifically talk about this, but I expect, since it is basically a no electronics class, the LS or any engine will need to be carb or mechanical injection with distributor or mag.
Old 02-20-2023, 08:21 PM   #6
e vassar
Liked 271 Times in 107 Posts
I don't know the rules for the classes, but I'll make a assumption no electronics would be delay boxes,throttle stops etc. Not engine mgnt systems.
Old 02-20-2023, 08:59 PM   #7
Adger Smith
Larry the way the class is structured I think your assumption about FI and Electronic ignition would be correct. It would not be in the spirits of the old Modified production. I've got an old Accel BEI ignition and cable drive tach I'm going to use.
Larry, I've even got an old set of Lee Shepherd Iron V-6 heads. I might show up with a V-6.
Old 02-21-2023, 01:17 AM   #8
Rod Greene
Liked 242 Times in 81 Posts
Originally Posted by Adger Smith View Post
Following.
Call Rob Youngblood at advanced clutches. He is the best in the business.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is online now   Reply With Quote
Old 02-21-2023, 01:09 PM   #9
weedburner
Liked 20 Times in 16 Posts
G101a and a diaphragm clutch controlled by a 'tamer. Coyote Stock cars all use this setup and are running upper/mid 9's @ 140, 3000lbs with factory sealed 302cuin naturally aspirated crate engines. Crowd pleasing 7500rpm dead hook wheelie launches are the norm, broken cars are rare. If you like people taking pictures of your car in action, screaming wheels-up launches are the way to go.
Even organic discs have been known to last a full season in Coyote Stock. Very consistent as well, field is usually as tight as NHRA Pro Stock. Here's a snip from a Dragzine article featuring Coyote Stock champ Clair Stewert, note the second to last paragraph...
With the 'tamer in place, there's no more juggling counterweight and launch rpm as conditions change. Completely eliminates the centrifugal vs base balancing act, as it allows you to adjust the launch separately without affecting high gear clamp pressure. Far simpler way to tune a clutch, and you won't need help from an expert to dial it in.
...If the clutch slips too much or not enough going into high gear, you know you need to adjust the spring pressure.
...If the clutch slips too much or not enough during launch, you dial that in with the 'tamer from the driver's seat.
The ability to control throw-out bearing position during launch can be a game changer.
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 02-21-2023, 02:36 PM   #10
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
A sintered iron setup will give long service life without having to constantly be under the car when setup correctly and last several seasons. A bellhousing that has a window to allow access for adjustments as needed, makes it faster and easier to work on. Rob Youngblood should be able to give some help on what he has to offer. I don’t have any experience with Cale’s Blackmagic clutches but they are popular too. Light base pressure is your friend and does not kill parts or your left leg!
For a trans you cannot go wrong with a G-Force.
Sean
Sean Marconette
84 Mustang
5060 SS/N
