Old 07-18-2022, 09:58 PM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default MSD Grid help
I want to change shift points for Onawa heat this weekend, haven’t touched it in 3 years
I called MSD and after 45 min on hold I hung up
What do I touch to accept the change
I know the light bar should go green, but nothing & my changes aren’t accepted
Thanks for any help
Randall Klein
Old 07-19-2022, 12:32 AM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: MSD Grid help
You should click on "send to MSD"
That will send the changes to your car from the laptop.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 07-19-2022, 01:16 AM   #3
Bob Sherwood
Liked 388 Times in 60 Posts
I think there will be several people at Onawa that will be able to get you fixed up. hope to see you there
Bob Sherwood is offline   Reply With Quote
Old 07-19-2022, 06:08 AM   #4
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Enter
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-19-2022, 07:26 AM   #5
Larry L.
Liked 4 Times in 1 Post
I use a MSD 7751 to change shift settings etc. Once it’s installed you can make changes without the use of a laptop.
Larry L. is offline   Reply With Quote
Old 07-19-2022, 08:35 AM   #6
Randall Klein
Bingo!
Thanks Dan Foley
Class Racer....better than most factory tech support
Old 07-19-2022, 11:34 AM   #7
B Parker
Liked 2,336 Times in 464 Posts
Make sure it says you are online. click connect then click send.. BP
