Liked 205 Times in 93 Posts
which manufacture? I have no experiance with them...LJ 350ci 2 bolt going to 4 bolt, 2pc. rear main seal style...tks
Liked 39 Times in 9 Posts
Milodon
Reggie Winkles 2650/Stock |
stronger just replacing factory 2blt caps?
Liked 974 Times in 310 Posts
Buy an aftermarket block.....better in the long run.
Liked 210 Times in 91 Posts
Richie lots of us here have started with passenger car blocks. Yes they are more expensive. Personally I have used passenger car blocks for 15 years. Racing blocks could have lasted that long and longer (racing blocks are made from harder material so your ring seal will last longer). I assume you will be racing for more years like most of us.
-4 bolt caps-$300 -4 bolt ARP bolts-$50 -line hone-$200 -Dart SHP block (can be bought cheaper than Jegs or Summit)-$1500 so $1500 minus $550 is $950. $950 over 10 years is $95/year. It is an investment you will not regret, Ray PS we have been using a 2 bolt BBC block in SS for years without failure.
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#7 | |
Liked 693 Times in 205 Posts
Put a set of ARP main studs in it and let it run.
Liked 60 Times in 12 Posts
If you have already spent a bunch on your production block, you might consider using main studs, and main cap straps. I have a 10 yr use block, with them on it.
2894 STK |
summitt 2k for a dart..... tks for everyones input...
