Old 10-26-2021, 12:47 AM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: TH350 Problem
Had a customer with a similar problem. took 4 runs to slow down and stabilize. turned out to be a worn converter sprag.
Adger Smith (Former SS)
Old 10-26-2021, 06:44 AM   #12
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Don't think that the case here. Change tranny out to spare trans with same converter and boom within 1-2 (60 ft) every run. Spare is just not as fast because it does not have alum stuff in it. Spare is an point A to point B trans.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 10-27-2021, 06:32 PM   #13
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Originally Posted by Terry Cain View Post
160
I assuming the pressure is the same in both trannys?
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 10-28-2021, 05:26 AM   #14
Terry Cain
Terry Cain's Avatar
Hmmmm, good question. Have not put a gage on "spare" trans because of no problems. All books and literature shows 145-170 is good number.
Terry Cain ???? STK
Old 10-28-2021, 11:10 AM   #15
Mark Ugrich
Liked 71 Times in 38 Posts
Is your pressure gauge mounted in the car or is it a diagnostic type for stationary pressure diagnosis?
Old 10-28-2021, 04:18 PM   #16
Jody Lang
Liked 89 Times in 28 Posts
Are the high gear clutched showing signs of slippage?
Jody Lang is offline   Reply With Quote
Old 10-29-2021, 02:21 AM   #17
Terry Cain
Terry Cain's Avatar
Trans guy says no although I'm glad you asked that. Well seasoned Super Stock racer in my area asked the same question. He said "I'll bet it high gear clutches or clearance issue."
Terry Cain ???? STK
Old 10-30-2021, 11:03 AM   #18
buzzinhalfdozen
Liked 11 Times in 8 Posts
Teflon and front pump has been out a zillion times. Not sure on temp but don't think that is the problem. Deep pan so it has an extra 2 qts. Sharver originally done trans yrs back. He plugged the coolant lines and did some drilling on pump to redirect fluid. The pump has been replaced and wondering if maybe that could be problem?
If the pump was modified for no external cooler and you've replaced the pump this may be your issue. not certain of it but thought they removed the cooler bypass valve to run no cooler, new pump having a bypass valve and setup for external cooler cause an issue with heat?
Joe Buchanan SS/BX 3117
Old 10-30-2021, 01:00 PM   #19
Liked 5,077 Times in 1,935 Posts
It should push through if outlet plugged..Doubt it would take any hp but worth looking at I suppose.
