Liked 184 Times in 113 Posts
Noticed that changing to the Stocker Cam from Pure Stocker.
Ran into two issues Cannot hold the Converter as much on Launch. Use to hold as much as 3200rpm. Now barely launch above 2500rpm The Line Lock will not hold the car during Burn Out. Have to power brake to get the tires spinning. Shut down after a run is no problem. Is there a good solution to get more Vacuum Boost for the Power Brakes? |
#2 | |
Liked 50 Times in 28 Posts
Dan, years ago I used to run one of these, the price has really gone up. https://www.summitracing.com/parts/c...+5ba2536e62314 |
Liked 43 Times in 25 Posts
a vacuum pump is needed .
You can use the one out of a G8 Pontiac / Aust Holden This : https://www.hella.co.nz/en/products/...pump-up28.html or this : https://www.amazon.com/ACDelco-20804...ic+vacuum+pump You can run full time , race only or switched Like this : https://www.amazon.com/Superior-Univ...HSQKDHY2J27ZZ3 Tex |
Liked 238 Times in 113 Posts
Remove the booster and switch to a manual master cylinder and save all the weight .
#8 | |
Liked 1,537 Times in 574 Posts
RockAuto has brand new master cylinders with the reservoir, Wagner P/N MC131285 on sale for $34.00. Also, search for a 1993 to 1996, 9C1 police car brake pedal assembly with the pushrod. They have a different brake pedal pushrod lever point. |
#9 | |
Got this one in today GM Genuine Parts 20804130 Power Brake Booster Auxiliary Pump Assembly Have to figure how to mount it and get a Male Connector. Dan Last edited by Dan Fahey; 09-22-2021 at 04:57 PM. |
here is another pressure switch
https://www.amazon.com/dp/B078T5NL4S/ref This is similar/same as what they use in the COMP and similar vacuum pumps If you want switched pump operation . Tex |
