Old 12-05-2020, 07:12 PM   #1
monte8616
Liked 14 Times in 6 Posts
Unhappy LOST 10mph AND ABOUT 6 TENTHS
So, I have gremlins in my car... the motor is fine on the dyno, the MSD and coil from the car are fine on the dyno... the trans is fine - the converter has been sent out and is fine... has anyone had any issues with a Racepak causing an issue like this?? It’s really the only change we made over the winter... car made a few good passes and then lost the time and speed... it’s quite a discouraging problem - if anyone has any ideas, please help!! Thanks!
Joey Cole - GT/DA - 454 BBC - Turbo 350
monte8616 is offline   Reply With Quote
Old 12-05-2020, 07:37 PM   #2
MR DERBY CITY
Liked 7,794 Times in 1,497 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Check fuel system, , the 30 second jug test is a good start, replace the battery/batteries....Have you done any welding close to the car ? .....Some racers have reported that their car became MAGNETIZED and they lost plenty of ET and MPH ......3 ideas to PONDER ......
Old 12-05-2020, 07:38 PM   #3
Jeff Stout
Liked 704 Times in 281 Posts
In my experience I lost .3 and 3 mph and chased it to find out fuel pump. I had gauge mounted on windshield and always showed the 6 psi range. But it did not have volume. No symptoms of miss or stutter just a full range of loss of ET.
Old 12-05-2020, 08:09 PM   #4
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
Check compression and leakdown , for engine health .
Old 12-05-2020, 08:15 PM   #5
monte8616
Did the fuel system test - all good - the welding is an interesting thought... batteries are pretty new - Racepak shows all good with fuel pressure... but something to think about with the volume - thanks everyone! Keep the ideas coming!!
Old 12-05-2020, 08:28 PM   #6
MR DERBY CITY
Just curious, how much did it pump in 30 seconds,.....carry on....
Old 12-05-2020, 08:29 PM   #7
monte8616
Gallon in 18 seconds so volume is good
Old 12-05-2020, 08:35 PM   #8
Jeff Stout
Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.
Old 12-05-2020, 08:36 PM   #9
Adger Smith
Liked 880 Times in 311 Posts
Put the 3 speed back in it...LOL
Do you run foam in the fuel cell?
Pull the cap off the fuel cell vent, check the vent for obstructions.
Adger Smith (Former SS)
Old 12-05-2020, 08:41 PM   #10
monte8616
I do still have the foam in the cell - thanks for the reminder - someone else mentioned that...
