Old 06-09-2020, 01:16 AM   #1
bykr
Liked 167 Times in 81 Posts
Default Update: lawsuit over cylinder heads
https://www.pacermonitor.com/public/...ociation_et_al
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 06-09-2020, 08:40 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Update: lawsuit over cylinder heads
In layman's terms, what does it mean?
Larry Woodfin 471W
Old 06-09-2020, 09:38 AM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Sure look like they are keeping the lawyers busy.
Is this the list or did I miss someone?
Plaintiff John Gulius
Defendant Wesley Roberson
Defendant National Hot Rod Association
Defendants Heads Up Cylinder Heads, LLC and Randy Brewer
Defendants Jeffery Taylor and Jeff Taylor Performance Engines
Stan
Old 06-09-2020, 09:44 AM   #4
nhramnl
Liked 358 Times in 83 Posts
Basically means that Roberson's attempt to dismiss the case was denied, and that the case will move forward (i.e. continue).
Old 06-10-2020, 03:40 PM   #5
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Also, the venue for the case against Randy/HeadsUp has been moved to Ohio, since the business is located in that state.
And for the same reason, the venue in the case against Jeff Taylor has been moved to Indiana.
