#21 |
Liked 920 Times in 259 Posts
Weight is weight. Lighter is better; faster or allows the weight you have to carry to be put where it is most beneficial. Dollars per pound reduction from the car is a consideration. Sprung vs. unsprung. Steel vs. aluminum vs. titanium. Mild Steel vs. Chrome-Moly. Fiberglass vs. carbon. The old expression is - The best way to save 100 pounds is find 100 places to remove a pound.
What about the lightweight transmission parts? |
#22 |
Liked 53 Times in 16 Posts
When I ran my 68 Impala 396/325 stick car I initially ran a standard gear, after 17 passes those blew up. Switched to Pro Gear lasted up to 100 passes in that car, same set and rear in my 65 Impala stick I will be running.
Will Lamprecht 65 Imp G,H,I Stock |
#23 |
Liked 1,428 Times in 296 Posts
Pro gears definitely! Of course, no matter what you do, the clutch you run and how you set it up has to be part of the conversation
James Schaechter 3163 STK |
#24 |
Liked 880 Times in 311 Posts
way back about 15 years ago I did some back to back testing between 1.82 and 1.76 planetary and the 1.76 lost almost a dime in my 10. second V-6 powered Gen 3 Camaro.
how much was due to the .06 in gear ratio?? not sure. My thought was weight of the rotating mass. It didn't pull of the gear change as quick.. I've always thought about building a 1.82 alloy planetary.
Adger Smith (Former SS) |
#25 |
Liked 34 Times in 7 Posts
With the quality of the ring and pinions, and the weight of your car, ( ie not a comp car) doubt its worth the risk....jus sayin
VENICE PERNO SS/CS 3041 NHRA SUPERSTOCK |
#26 |
Liked 358 Times in 83 Posts
OK, so the consensus is that lightened ring gears are not of any value. How does everyone feel about the other available ring and pinion treatments, cryo, shot-peening and micro-polishing (which MW calls Supra-Fin)? I'm going to make a gear change before spring, and think I'll opt for cryo treatment, but that will be it. Any strong evidence to change my plan?
#27 |
Liked 225 Times in 136 Posts
Most are shoot penned in production at some phase.
