Old 09-13-2019, 11:32 AM   #61
Liked 10,711 Times in 2,230 Posts
Default Re: We're Baaaack!! "Live from Earlville 2019"
I will take some pics of the Cuda when we get to Great Bend and post them on that "Live" from!
Patsy
Old 09-13-2019, 01:08 PM   #62
jmcarter
jmcarter's Avatar
Liked 3,179 Times in 972 Posts
Patsy, it was great to see the Cuda running on Warren’s broadcast. Hope you and Larry have gone on YouTube and watched it.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-15-2019, 10:50 AM   #63
Doing normal maintenance on trans, oil and filter change, I found broken brake line on rear housing. Cause of failure; vibration and improper mounting. So now going into the fourth round I will have a new brake line and fresh brake fluid. And a test and tune day to make sure everything is OK.
Moral of the story, be safe and check you stuff.
Old 09-18-2019, 07:54 AM   #64
We left yesterday to travel to the site of the first Nationals, Great Bend Ks. Got as far as west of Wendzville Mo. on I-70. We got lucky and pulled into a rest area at 9.30 pm and found a spot to park and put the bedroom slide out. I sure hope I didn't use all my luck on this trip in a rest area.
Old 09-18-2019, 08:39 AM   #65
Bobby DiDomenico
Liked 101 Times in 52 Posts
Larry,
That's why I always suggest the drivers go visit the safety trap at the end of the track before running. Glad you caught and repaired it, good luck and safe travels.
Old 09-18-2019, 10:03 AM   #66
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Great catch although, if you're going to lose your brakes somewhere, Great Bend would be a pretty good choice.
S/ST 51
S/C 53
