Old 07-24-2019, 11:31 AM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default 350 SBC Crankshaft Advice
Hi all,
I went looking through the tech specs to see if NHRA added any aftermarket replacement crankshafts for Pontiacs, which they did not.
So I went over to the tech specs for a SBC crankshaft and I found this crankshaft which is a Callies SAF113-CM listed as an NHRA legal replacement crankshaft for a 350 / 305 SBC in STOCK Eliminator.
Turned down flange, lightening holes in all rod journals, pendulum type counterweights and bull nosed…….
I don't understand the NHRA logic.
Take a look and see what you think????????????
Name:	callies crank front.jpg
ID:	50735   Click image for larger version
Name:	callies crank rear.jpg
Bob Mulry 7516 STK
A & M Motorsports
Old 07-24-2019, 12:10 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: 350 SBC Crankshaft Advice
No matter what the crank looks like , the one thing that remains the same is the bobweight . If the rod throws are drilled then extra weight has to be added to the counter weights . You might be able to get a similar crank approved for a Pontiac , which I hope you do !
Old 07-24-2019, 01:00 PM   #3
GTX JOHN
The counterweight configuration has a very significant reduction
in windage = real horsepower gain.
I built a plexiglass side on a Mopar pan once to observe the windage.
I would kill to have a crank like that especially in my high RPM small
block combos.
That Crank is a JOKE.........I hope!
John Irving
741 Stock
741 Super Stock
Old 07-24-2019, 05:09 PM   #4
ss3011
ss3011's Avatar
I agree that an improvement in windage helps HP . The crank is definitely part of that equation , baffling is part of that too . However that crank was approved , just needs to apply to all makes . Someone just took the initiative to send a crank in , and ask for approval .
Old 07-24-2019, 06:04 PM   #5
Billy Nees
Liked 7,807 Times in 1,748 Posts
Originally Posted by Bob Mulry View Post
Hi all,
Bob, ya know how hard stock small-block cranks are to find! Pontiac stuff just falls out of trees!
Billy Nees 1188 STK, SS
Old 07-24-2019, 08:14 PM   #6
Ed Wright
Ed Wright's Avatar
Why not send a light Pontiac Crank in for approval before complaining. Somebody went to that trouble to get that approved. As hard as it would be to find Pontiac cranks, it may be easier to get approved.
Ed Wright 4156 SS/JA
Old 07-25-2019, 12:14 AM   #7
Bob Mulry
Bob Mulry's Avatar
You have that backwards...Take additional weight off off the counterweight to make up for the lightened journal..
Bob Mulry 7516 STK
A & M Motorsports
Old 07-25-2019, 12:18 AM   #8
Bob Mulry
Bob Mulry's Avatar
I don't think that Callies would be interested in duplicating that SBC in to 400ci Pontiac piece..
Maybe they could sell 20 a year vs a SBC...They get the economy of scale
Bob Mulry 7516 STK
A & M Motorsports
Old 07-25-2019, 03:21 AM   #9
Race Clean
Liked 129 Times in 53 Posts
I evidently need more education about this!
Race Clean is offline   Reply With Quote
Old 07-25-2019, 08:22 AM   #10
ss3011
ss3011's Avatar
Yup , Thought backwards on that one !
