09-02-2018, 05:35 PM | #1 |
Liked 25 Times in 13 Posts
Quadrajet Needle & Seat
What is the best needle and seat for a Quadrajet? This is for an Ashley stocker carb, return style fuel system, and 6.5 lbs fuel pressure.
Windowed - Non Windowed ? Best diameter - .124" .125" .132" .135" ? Best place to purchase and part numbers would be appreciated.
Dean Feiock -- Stock 5002 |
09-03-2018, 12:00 PM | #2 |
Liked 1,469 Times in 549 Posts
Re: Quadrajet Needle & Seat
If you can find them, the Grose-Jet assemblies are the best.
Once in a while you can find them in Ebay. Also, Jet Performance carries all sizes of QJ needle & seat assemblies. |
09-09-2018, 10:37 PM | #3 |
Liked 23 Times in 19 Posts
Edelbrock used a .149 in there 1910 Qjet. You can drill em & experiment.
09-11-2018, 11:00 AM | #4 |
Liked 353 Times in 83 Posts
Dean Oliver would tell you to stay away from the .149 Edelbrock needle and seat. He says he has helped a lot of racers who were having acting rich/flooding-type problems simply by having them switch to a smaller, "traditional" orifice size. He helped me with a car that was so blubbery at idle and around the pits that it would actually smoke gray. I switched the needle and seat, verified the float setting (it was right) and I had a different car. Dean's theory is that the .149 passes so much fuel that it creates turbulence that prevents the float from seating properly, which obviously makes the car flood.
09-11-2018, 11:09 PM | #5 |
He would know. I'd say depends on fuel pressure, I'm running .144 with 6-6.5 psi in my street car.
09-12-2018, 07:21 AM | #6 | |
I agree completely and probably should have said that. Dean said that some carb/engine combinations seem to get along fine with the .149, but when somebody calls with a "No matter what I do, the damned thing acts real smoky rich at idle and at slow speeds", the first thing he asks them is "Do you have a "big" needle and seat in the carb?". If they do, he tells them to take is out and replace it with a smaller one. I was honestly skeptical of something that simple fixing my problem, but the problem literally disappeared. Dean has been my 4GC and QuadraJet guy for many, many years, and has never given me bad products or advice. |
09-12-2018, 01:03 PM | #7 |
Liked 24 Times in 12 Posts
Great topic Dean. I'm hearing "smaller" than .149. How much smaller? I know mine is bigger that the .125 as my 1/8 drill bit is loose. I will check it with pin gauges at work today(on break of course... ) and let you know. There are several on ebay under "quadrajet needle".
09-12-2018, 01:06 PM | #8 | |
09-12-2018, 03:42 PM | #9 |
Just call Dean direct and he'll evaluate what you've got and make a recommendation. Dean Oliver - 870-830-5470
09-14-2018, 07:14 AM | #10 | |
Liked 727 Times in 152 Posts
I found the .135 size with a window works well. Anywhere from 6.5 to 7.5 for fuel pressure works for this.
Todd Hoven 1035 Stock |
