Old 02-12-2018, 07:16 PM   #1
HammondRacing
Liked 6 Times in 4 Posts
Default Water in radiator rusty looking
What do you all put in water in radiator to keep from getting rusty looking? I took motor out and apart for some head work and the water looks like it came out of a old tractor that been setting for years. Motor was only together for 9 months. It is a dart block
HammondRacing is offline   Reply With Quote
Old 02-12-2018, 07:25 PM   #2
HR9121
HR9121's Avatar
Default Re: Water in radiator rusty looking
I use Water Wetter it seems to work pretty good.
James Williamson
W200 J/SA. SS/JA
Old 02-12-2018, 07:47 PM   #3
4406mopar
Liked 120 Times in 53 Posts
How do you clean out a rusty cooling system like the one described above. I'm looking to clean it in the car, not tear down the engine. Thanks
4406mopar is offline   Reply With Quote
Old 02-12-2018, 10:28 PM   #4
David Lee
Liked 346 Times in 126 Posts
what is the material of the core?
Old 02-12-2018, 10:40 PM   #5
paul romeo
I have not tried this product Thermocure made by evapo-rust but have seen it on tv looks to work excellent. Paul
paul romeo is offline   Reply With Quote
Old 02-13-2018, 10:27 AM   #6
Jeff Niceswanger
Liked 1,031 Times in 368 Posts
https://www.summitracing.com/parts/jgr-50030
We used this for a while . Still have 5 or 6 bottles around here somewhere. Works well, but it foams a little in a unpressurized system ..We only used half a bottle per fill
Jeff Niceswanger 3740 SS
Old 02-13-2018, 11:41 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,924 Times in 578 Posts
I never leave the water in my engine
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 02-13-2018, 01:43 PM   #8
Jeff Stout
Liked 704 Times in 281 Posts
I thought using thread cutting oil in radiator. 1 shot glass worth
Old 02-13-2018, 01:45 PM   #9
CMcAllister
Liked 920 Times in 259 Posts
If you have an electric pump on it, drain it including pulling the plugs in the block. Refill with fresh water and a can of some type of cooling system cleaner. Circulate that for awhile and drain again. Circulate and run clean water through it until it runs clean. Refill and include a can of additive. Without block drains and an electric pump, it becomes a little more involved.
I used Justice Brothers products because I sold them and they worked well. Any quality anti-rust product should prevent the coolant from turning to mud.
Old 02-13-2018, 04:07 PM   #10
Jeff Stout
Could you use CLR safely to clean? I always thought if you drain water and let metal sit exposed to air it would promote rust
