Old 11-12-2017, 10:06 AM   #1
Spyphish
Liked 679 Times in 180 Posts
Default Lead Sled class
What class will a 1966 Miller Meteor fit in? Weighs about 7000ish.
Also, can the sick dude ride in it while racing? Seems someone did that recently. VALDEZ
ID:	43688   Click image for larger version
ID:	43689   Click image for larger version
Old 11-12-2017, 11:03 AM   #2
Billy Nees
Default Re: Lead Sled class
http://www.classracerinfo.com/Classi...E=8456&TRANS=0
Check it out, wise guy. They exist with no-one to build them. But I DO like the Blues Brothers car.
Billy Nees 1188 STK, SS
Old 11-12-2017, 12:00 PM   #3
Billy Nees
http://classracer.com/classforum/showthread.php?t=27885
or maybe some of these!
Old 11-12-2017, 05:26 PM   #4
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Is that carb a legal replacement? better check all the numbers......
Old 11-13-2017, 10:13 AM   #5
Spyphish
This sled wasn't shifting right so we dug out the shop manual that came with it. In top engine photo notice a thing-a-ma-jig with wires below carb. That was a stuck two stage solenoid that should touch a bell crank. Could not find parts on the planet so we drilled the brads, repaired guts and tie wrapped back together. Rigged a lever on our incorrect carb and BAM. At 40% throttle the shift kick down and at 60% you hear a click in the tranny and the stator blades in the convertor go to performance mode. Pretty slick for 1966. That with the 3:40ish pos truck axle makes for a little pep in this baby. Plan on having it ready for Houston Spring Nationals.
WHO YOU GONNA CALL????
ID:	43698   Click image for larger version
Old 11-13-2017, 10:25 AM   #6
Billy Nees
That thing really needs a bar in it!
Old 11-13-2017, 12:02 PM   #7
Spyphish
ROLL or WET? LOL
Old 11-13-2017, 01:35 PM   #8
Billy Nees
Why wet!
Old 11-15-2017, 07:50 AM   #9
goinbroke2
Liked 404 Times in 158 Posts
SS/PA at 4250#
Make a hole in the track if it ever came crashing down after dragging the bumper. Lol!
Is that its name? Valdez? Quite fitting, haha.
Old 11-28-2017, 12:10 PM   #10
Spyphish
OK, found one a little lighter (very little) but am concerned if the chassis will rotate. Instead of oiling the track, we will drop flower petals each pass. Phish
