Old 10-19-2017, 11:33 PM   #1
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Brakes Fix
Since I got my Camaro a year ago with 4 wheel Strange disc brakes and what appears to be a stock master cylinder it took a lot of pressure to hold the car on the starting line. I attempted to footbrake (no 2 step) and could not do it without pushing through the beams. I was about to change the master cylinder to one Strange recommended but remembered that I read somewhere to swap the lines on the master cylinder. I tried it and it made a night and day difference on how it holds on the starting line. Amazing what a few minutes of work will do for you sometimes.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 10-20-2017, 12:26 AM   #2
TommyPettigrew3076
Liked 26 Times in 11 Posts
Default Re: Brakes Fix
How was it set up before ? Strange instructions recommend the rear outlet be plumbed to the system with the most volume ( the rear ) My S-10 style the front was plumbed to the rear. I Changed mine to a strange 1 inch piston diameter and the pedal ratio they recomend its a lot better but I am still not 100% happy with it .
TommyPettigrew3076 is offline   Reply With Quote
Old 10-20-2017, 11:09 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have Strange on the front, too. I ran the recommended master from them and had trouble staging like I was used to with power brakes. This was just a continuation of the issue I had with Wilwood and other manual masters so I ditched it and went back to power. It's a Powermaster MC and booster with an electric vacuum pump. Bumps into the lights and makes the first turnoff from 110. Bulky and heavy, but it beats red lights and deep stages.
Dale Shearon
68 Mustang 6394
Old 10-20-2017, 11:30 AM   #4
Darrel Goheen
It had the rear port (closest to firewall) going to front brakes and the front port going to rear brakes. I just swapped them and fixed it. Sure glad I didn't put the $180 master cylinder on.
Old 10-20-2017, 11:32 AM   #5
Darrel Goheen
When I stage now it's like I have power brakes. If I bracket race next weekend I'm going to try footbraking with no 2 step.
Old 10-20-2017, 02:09 PM   #6
Dickens
Liked 12 Times in 8 Posts
My brake lines on my Firebird were reversed during assembly too. I bent the rear backing plates trying to hold the car with drums on the rear...very ugly situation.
Glad you found it without damage !
DD
NHRA7010
Dickens is offline   Reply With Quote
Old 10-21-2017, 06:11 PM   #7
Coleydog
Liked 53 Times in 38 Posts
How well does it stop at speed? Does it pull or try to lock up the rears?
Mike
Old 10-22-2017, 11:41 AM   #8
Eman
Liked 133 Times in 76 Posts
Unless the MC is a stepped bore, one section a different size bore than the other,I don't understand the hydraulic principle of how braking is improved by swapping lines. Generally MC's have the same bore throughout and the difference between ports is the size of the resevoir. The disc brake section has a larger reservoir so as the pads wear there is enough fluid to fill in.
Possibly your pedal rod doesn't have full travel as it's binding as it goes into the MC many times due to rod relocation attempting to increase pedal ratio.
Old 10-22-2017, 11:51 AM   #9
340Cuda
Liked 801 Times in 338 Posts
If you want to really be able to hold you car on the line with disk brakes, go with the dual rear calibers. In my experience they work very well. Mine are Strange but I would think others would work well also.
Bill
Old 10-22-2017, 02:34 PM   #10
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Pedal ratio is most impoetant on these aftermarket brakes. I am in the middle of it finding my ratio is 7 to one when I need 6-1. I have approx 800 psi and and going to make pedal correct this week looking for 1000 at rear.
Always listen to the manufacturer of your master cylinder.
It did not click w me intil we spoke at work and realized its like using a pry bar and the leverage needed.
Chris
chris ok is offline   Reply With Quote
