Old 10-14-2017, 10:32 PM   #1
Weekend Racer
Default oil leak
Diff leaking through pinion nut thread,12 bolts chevy, Mark William Yoke ,solid sleeve, Amsoil 75W-90 synthetic .Any idea what going wrong?
Thank!
Weekend Racer is offline   Reply With Quote
Old 10-15-2017, 01:02 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: oil leak
Many of the new nuts have a sealer pre-applied to the threads and flange .
Old 10-15-2017, 03:26 AM   #3
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Can't be leaking much, as you described. Reapply the pinion nut after loading up with silicone. Or, if you dare, jb weld
Old 10-15-2017, 08:25 AM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Permatex makes an RTV specifically for gear oil. I used it to stop the weeping along the pinion splines.
https://www.permatex.com/products/ga...-gasket-maker/
"That'll never work....."
Old 10-15-2017, 12:14 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I thought that everybody put PTV on the inside of the companion flange spline, so that when the flange went onto the pinion any air gaps could be taken up. The extra RTV would be pushed out and end up under the washer and make it a double seal...splines and washer..
Been doing it that way for 50 years with good results..
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 10-15-2017, 02:07 PM   #6
Weekend Racer
Thank you everybody for your advices !!
