Liked 13 Times in 11 Posts
I want to get the car to "wheel stand" without changing the ride height of the car. If I drop the front of the bars down one more hole , which naturally increases the pinion angle also , without moving the housing down , do you think it makes the car more wheel stand prone?
There is a point , I guess , where dropping the bar down becomes counter productive and you just HAVE to change the ride height. |
Liked 126 Times in 61 Posts
Raising the front of the bar will make it want to wheel stand more.
Liked 53 Times in 13 Posts
Without changing the ladder bar location is the rear end housing floating on the leaf spring perch? if its too tight then it's binding and this will kill your effort. . Luke SS311
#5 | |
Liked 3 Times in 1 Post
Really not enough information to answer the question. A good general starting point with ladder bars is make the bottom bar parallel with the bottom of the car not the ground. Give it 2-5 degrees of downward pinion angle and see what happens. |
If you are not using floating spring perches, it is binding. WD40 is not a good lube. I ran ladder bars with leaf springs back in the '70s. On 10.5" tires. Hooked better when I went to mono leafs, then still better with the floaters.
Ed Wright 4156 SS/JA |
#7 | |
I'll move the bars up a hole and see what happens............for some reason I always assumed going down makes it more wheel stand prone...... ![]() |
Use some good moly grease to lube everything. Mine was a C/Super Modified '69 Camaro. 302" on 10.5" tires. Making it wheel stand was never an issue. Don't think I ever moved the bars up or down.
Liked 1,925 Times in 579 Posts
Just don't move the bars past level with the bottom of the rocker panel. Mine has a down angle of 1-2 degrees. Horsepower and good chassis is what will make the car get up in the front. Moving the bar down will make it hit the tire harder.
Mike Pearson 2485 SS |
#10 | |
Since I lowered the ride height in the rear it wont..........so to recover ( some ) I either move the bars or lower the housing on the perches.....I dont want to raise the azz end up a hole on the perches , sooo.........past level? I'm already slightly down a degree or so............so I either go down more ![]() The consequence of breaking parallel , at least from going DOWN some is already noted. The result of going UP is not. |
