Liked 46 Times in 29 Posts
Which of these is preferred.pro gears in a heavy car.
Chris |
Liked 880 Times in 311 Posts
The one with the most teeth on the pinion would be my choice.
Pinion, That is where the failure usually starts...
Adger Smith (Former SS) |
Liked 704 Times in 281 Posts
Just took my 4.30 pro gear out. Went with 4.88 pro gear as I have been running 1/8 mile. Car is 3360 lb. w/trans brake, w/sbc and with 220 runs they are perfect and quite. I would sell them cheap if interested.
Liked 642 Times in 192 Posts
Jeff check your pm
Thanks Nick |
Liked 431 Times in 224 Posts
x2
S/ST 51 S/C 53 |
Looks like 430 it is
10 vs 9 Thank you Adger for info Now to find a set If the sale here falls thru let me know Otherwise if someone has a new set I'd be interested right now. Chris |
I stand corrected. I just checked mine in box and it is 4.33 ratio. 9 pinion and 39 ring gear. Car has been 9.0s with 1.32 sixty on 10 inch tire and gears look excellent
You know what, I didn't think deeply enough when reading that. I would go with FEWEST teeth on the pinion gear. That means the teeth that are there, are thicker/stronger.
Sorry for the confusion!
S/ST 51 S/C 53 |
#9 | |
Banned
Liked 179 Times in 89 Posts
Maybe it's just me but I like the bigger pinion. |
As the pinion gear gets more teeth on it the diameter usually increases.
That increase in size has an effect on increasing the root width and diameter of the gear teeth. You need to check it to be sure, but it is usually the case. Ask an old Modified or Gas racer which gear set held up better. Dana 6.50 or Dana 6.17. 6.17 had a larger diameter pinion gear.
Adger Smith (Former SS) Last edited by Adger Smith; 06-10-2017 at 02:13 AM. Reason: sp |
