Old 06-01-2017, 12:13 AM   #1
David Lee
Liked 346 Times in 126 Posts
Default Drum brake pads
what is a good source for drum brake pads being used on 10x2.5" brakes for a k class car. The fronts will be 11" willwoods
Thanks
Old 06-01-2017, 07:13 AM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: Drum brake pads
Thanks
Dave,
I think you mean brakes shoes.
Disc brakes use pads
Drum brakes use shoes
OEM is fine for most applications.
Mike A114
Old 06-01-2017, 08:08 AM   #3
Jim Kaekel
Liked 531 Times in 108 Posts
Brake shoes that are riveted are generally the higher quality.
Jim Kaekel 3836 STK
Old 06-01-2017, 08:09 AM   #4
Woodfin
Liked 274 Times in 105 Posts
David, find a local parts store that sells Wagner brand. Ask for "riveted" it will have an "R" after the part number. [they may have to order them but most stores are connected to overnight sources]
Those are excellent quality and will do well for you.
Old 06-01-2017, 11:35 AM   #5
Dave Gantz
Liked 251 Times in 125 Posts
Years ago, Napa sold metallic or semi-metallic shoes. I don't know if they still do.
I put metallic (or semi) shoes on the back of my 87 Mustang. I'm pretty sure I got them from Maximum Motorsports. I'm guessing that MM got them from someone who maybe makes them for other apps.
"Don't know", "pretty sure", "guessing", and "maybe", lol, it's all I got.
Anyhow, I like them on my Mustang.
Old 06-01-2017, 12:25 PM   #6
David Lee
Thanks all, I got the wagners, turns out that Amazon was the easiest place to find them
Old 06-01-2017, 03:43 PM   #7
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Here's a link to the folks whose brakeshoes I've used on the 'wagon. Very good quality and a number of options for you.
http://musclecarbrakes.com/
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-01-2017, 05:06 PM   #8
David Lee
Lew
Thanks Lew, if these brakes i bought from wagner do not work out i will look at these.
Old 06-01-2017, 08:21 PM   #9
Bench Racer
Liked 99 Times in 21 Posts
This thought process may be of some help. Several years ago I was going to re do the brakes on my OLD Ford tractor that has mechanical drum brakes. I spoke with a brake rebuilder in Asheville, NC. He told me that routinely used a very soft shoe for the old tractors to aid with stopping as it had better gripping with the drum. He sad he had many times replaced shoes on a new tractors with the soft shoe to aid breaking in the mountains. If you have been through N.C. to Bristol you have seen the terrain he is talking about. An 8N Ford with a 1/2 ton of fire wood behind it idling down a steep incline,, you get the picture. I would see this brake shoe issue no different than a Stocker foot braking against the converter. It might be worth looking into what some brake shoe rebuilder's have. My Dad was an Old School mechanic and flat head racer back in the 1960's. I remember as a kid he used a lot of profanity when it came to hard as diamond "lifetime" brake pads and shoes that his customers wanted. He said they are harder than the damned drums and rotors and squeal like hell, what would you rather wear out first the pads or the rotors. Just my .02. Don Jackson
Bench Racer is offline   Reply With Quote
Old 06-01-2017, 11:07 PM   #10
Everett Vassar
Liked 2 Times in 2 Posts
I know I didn't dream this. ...but I had a racer once tell me he was using forklift brake shoes on one of his cars.
Everett Vassar is offline   Reply With Quote
