Old 05-11-2016, 12:59 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Thumbs down 440 pushrod problem
my dad runs a 440 in a 70 challenger.
it has:
Indy alum heads
Crane rockers
Mancini shafts
Indy pushrods
He has been running this combo for 3 years. he went to check the valves and look over everything and found 2 pushrods on each side burned on the ends and cracked. Appears they are not getting oil. Talked to Indy and Hensley and they really haven't had this problem. has anybody ever had this problem? Open to suggestions
jaf2021 is offline   Reply With Quote
Old 05-11-2016, 02:16 PM   #2
rk3800
Liked 101 Times in 33 Posts
Default Re: 440 pushrod problem
Yes, I had the same problem with my Super Stocker. I was using Trend
pushrods the Chrysler type which were supposed to be the hot ticket at
the time. Only one or two would randomly do this, but I never knew which
one until after they were discolored. It wasn't the lash adjustment. I never
did figure it out. I changed the adjusters on the Jesel rockers and went
back to a Chevy type pushrod. No more problems. 305 Chevy
rk3800 is offline   Reply With Quote
Old 05-11-2016, 10:26 PM   #3
jim morgan
Liked 52 Times in 9 Posts
Call Al @ Manton pushrods he helped me out last week.
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 05-17-2016, 04:43 PM   #4
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
You need more oil to the top of the engine. Start by replacing the 3/8 oil pick up with 1/2 inch, and high volume pump. Do you use lifter bore bushings? Also, run additional oil lines to each oil galley by tapping into them and oil supply line tapped into the block near the oil pressure sender. Problem solved.
Old 05-20-2016, 04:30 PM   #5
Wayne Kerr
Liked 26 Times in 11 Posts
Groove the #4 Cam Journal like a HEMI.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 05-31-2016, 12:12 PM   #6
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
While grooving the #4 cam bearing is fine Indy heads are not fed oil that way to the rockers. They are fed through oil lines at the back of the heads. Burnt tips are obviously from an oil issue. Look for issues with the rockers that had pushrod problems. I do not and will not run the Indy/Dove rockers but you may want to check them for obstructions or possibly the adjuster is out to far not letting oil pass through to the tip....If that is the case the pushrods are the incorrect length.
sst7250 is offline   Reply With Quote
