Old 12-03-2007, 10:57 PM   #1
Uncrated
Banned
Default Hot Rod Heritage [gas class cars]
I would like to see the "Gasser" rules. If someone can post a link that would be great.
Thanks
Larry Woodfin
Uncrated is offline   Reply With Quote
Old 12-03-2007, 11:10 PM   #2
Chuck Norton
Liked 89 Times in 19 Posts
Default Re: Hot Rod Heritage [gas class cars]
Unless there's been a change in the system, the "Gasser" classes are merely "Super" classes with a different set of indexes. For example, the Good Guys ran "D Gas" with a 10.60 index. I believe that "C Gas" was a second quicker. Other than that, it was the same as the Super classes only you need a car that meets their criteria in terms of age and a few other limitations.
Chuck Norton is offline   Reply With Quote
Old 12-04-2007, 12:06 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Nostalga Gassers are only allowed air shifters, no timed throttle stops or limiting devices, except for weight or a bolt under the pedal. ....You are correct that they are no break out, index classes, 7.60, 8.60 ,9.60 and 10.60. No tire or engine limitations , only model year .... Tom
Old 12-04-2007, 01:54 AM   #4
Mark Tallent
Question Re: Hot Rod Heritage [gas class cars]
Tom, Explain to me how you can run an "Index" class and not "Breakout"?
Mark Tallent 7724 STK, SS
Mark Tallent is offline   Reply With Quote
Old 12-04-2007, 09:38 AM   #5
Tom Goldman
I should have said no break outs allowed. ...... Tom
