Old 11-10-2015, 02:16 PM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Boss Mustang stocker
looking good,Bill
Mike Taylor 3601
Old 11-10-2015, 05:38 PM   #12
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
The rest of the sheetmetal parts are down here....
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 11-10-2015, 05:41 PM   #13
Bill Diehl
Bill Diehl's Avatar
I was going to rebuild the factory headlight assemblies..but being 45 years old and they looked like they were 145 years old, I got these instead.
These things are really nice even if they are offshore clones
Old 11-10-2015, 05:43 PM   #14
Bill Diehl
Bill Diehl's Avatar
and they will bolt on to this....
Old 11-10-2015, 06:04 PM   #15
Bill Diehl
Bill Diehl's Avatar
If it wasn't a cleveland I wouldn't be using these, but it does make for a nice way to restrict the oil, should have posted them a few pics back with the rest of the cam gear
Old 11-11-2015, 01:15 PM   #16
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Looks nice. What's your source for sheet metal? I used mostly Dynacorn stuff from CJPony Parts to rebuild my 68 coupe. Floor pans, radiator support, a fender and such. Pretty descent stuff for Korean stamping.
I don't have access to a rule book on this computer but I think you are allowed to cut that cross member for header clearance.
Dale
Dale Shearon
68 Mustang 6394
Old 11-11-2015, 01:36 PM   #17
Bill Diehl
Bill Diehl's Avatar
Dale
Dynacorn, and I am happy with the parts. I noticed they just came out with a strut rod crossmember, for the 71-73 .......now I can start putting the front end back together.
I am tig welding all the panels back in also, but its a slow process in between bending tubing for the roll cage and pouring concrete for a living
Headers where designed for the engine to sit lower.....but rules state I cant do that, raise the engine to stock location they hit the floor, lower the engine hits the crossmember..no problem, I have a plan
wish I could use a dif intake manifold though, I have the best set of heads on the planet (nobody has anything close) with the worst manifold bolted to them
Old 11-12-2015, 04:31 AM   #18
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
With that statement, I just have to ask. Why are they so much better ?
Can those cam beearings be used with an iron cam ? Comp told me 400lbs open was about it for an iron cam but those 1427's are 500 @ .600" so a tick less with the Boss cam.
Dave Noll, EF/S ,?/SA 6526
Old 11-12-2015, 08:47 AM   #19
Bill Diehl
Bill Diehl's Avatar
You will just have to believe me
Old 11-12-2015, 09:01 AM   #20
Bill Diehl
Bill Diehl's Avatar
The exhaust crossover, lead is too much of a hassle, tin leaks....aluminum plate works much better and don't have to worry about anything falling out or finding its way into the exhaust bowl. and I am able to swap manifolds without screwing around with it.
