Old 10-06-2015, 10:44 PM   #1
Run to Rund
Liked 54 Times in 27 Posts
Default lifter metering plates
I am using solid lifters with 0.520" OD, 0.015" thick oil feed metering plates (for the pushrods-rockers) that have four offset holes in them. I would like to find plates with no hole or with a single small, offset hole. Does anyone know where I might find some, or what lifter might come with what i need in it.
Old 10-07-2015, 01:41 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Default Re: lifter metering plates
I made some recently out brass shim stock using gasket punch,if you have room sandwich it in with existing plates.
I used .005 thick most likely you will need to cut small groove in plate you have now so oil can get through.
The ones I did once the were in there they couldn't get out.
Mike Taylor 3601
