Old 09-21-2015, 10:46 AM   #41
btrc
Liked 84 Times in 42 Posts
Default Re: FS/H CobraJet Body In White Project
looks real good George. Where can I get a set of those spiffy Ford fender covers? One thing that was handy on the Holley EFI I used was that it hooked up to the stock temp sending unit.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 09-21-2015, 11:20 AM   #42
Sam M
Sam M's Avatar
Sweet George! get her done and do Indy next month... haha I know it's a lot easier said than done.
Sam Monteleone
3348 S/SS
Sam M is offline   Reply With Quote
Old 09-21-2015, 07:49 PM   #43
STEVEB
STEVEB's Avatar
Beautiful build!!
STEVEB is offline   Reply With Quote
Old 09-21-2015, 08:35 PM   #44
Bob1320
Bob1320's Avatar
Great progress George Looks great.
Bob1320 is offline   Reply With Quote
Old 10-18-2015, 10:56 PM   #45
George Wright
George Wright's Avatar
Liked 404 Times in 35 Posts
More progress on the CobraJet. Hooked up the laptop to the BigStuff ECU and started the engine today so I could check the cam crank advance number. My Browell bellhousing is ready to go in so hopefully I can get it in early this week and finish up a few details by next weekend.
4 inch aluminium driveshaft from Raven Engineering.
Radiator and radiator hoses installed.
View of carpet and seats from drivers side. I found a new carpet that did not have any cut outs in it. I then cut holes for the removable shifter covers.
I fabricated a throttle cable bracket since I am no longer using the drive by wire.
I fabricated a small aluminium bracket to hold the BigStuff air intake temperature sensor right above the throttle body opening.
Here is the bracket to hold the electric water pump drive motor.
From here you can see the Moroso pcv filter and the electric water pump drive motor.
More photos at http://9500rpm.com/GWCJ/index.html.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 10-19-2015, 09:04 PM   #46
Sam M
Sam M's Avatar
Looking good George!
Sam Monteleone
3348 S/SS
Old 10-26-2015, 11:24 PM   #47
George Wright
More progress. The Jerico and Long shifter are now in. The car was scaled. It weighs 3010 pounds with me in it (no weigh box). The pinion angle was set. The pre-load was set using the anti roll bar. Tomorrow I will check and set the front end alignment. Still need to carpet the rear seat area, but that wont stop me from testing the car. Hope to test it this coming weekend.
Old 10-27-2015, 10:21 AM   #48
btrc
Looks great George. I do like the blue. I've had a question ever since I saw this was going to be a manual trans. I know you are using a 4 speed but did Ford "offer" a 5 speed version also?
Bob Tilton
568 FS/H
Old 10-27-2015, 10:34 AM   #49
George Wright
Thank you.
Yes. The Liberty LSC5100 was available.
Old 10-27-2015, 05:23 PM   #50
Bob1320
Bob1320's Avatar
Looking good George...Hope the testing goes well.. let us know ...
Bob
