Old 02-25-2015, 11:13 PM   #1
Liked 5,121 Times in 1,952 Posts
Default SBC Roller rockers Accuracy
I have a cam with a few thou safety factor built into the lobe lift, so now I need rockers that are true 1.5 or at least check that way with near stock length push rods.
What brand in new ones, or I'd take some low mileage used ones (7/16 hole).
Thanks in advance
Old 02-26-2015, 12:06 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: SBC Roller rockers Accuracy
Thanks in advance
Mark,
Harland Sharp makes a very accurate SBC roller rocker.
Also, I believe T&D Machine is also making Stock Eliminator legal roller rockers.
Old 02-26-2015, 12:28 AM   #3
I have been told that. Also told if you want a say a 1.46 you can get that too ..within a matter of a few days.
I like the sound of that..
.Anybody else...similar experience?
Old 02-26-2015, 07:10 AM   #4
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Mark,
Harland Sharp will work with you and build what you want. Call them and ask for Randy Jr.
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 02-26-2015, 08:31 AM   #5
Liked 1,826 Times in 414 Posts
Mark, talk to Tim Cole at Comp Cams. He had special rockers built specifically for Stock Eliminator, they're a true 1.5:1 ratio, they're fully rebuildable, and come with a set of ARP studs. They keep them on the shelf and ready to ship.
Old 02-26-2015, 09:54 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Mark,
I needed some the opposite way last year,so got a few sets in hoping they would be off,tried scorpion, and ones that Liberty engine parts sells,and they all were good on the ratio,I was surprised,the liberty ones I sell for about $175.00 alum or steel version,maybe PRW makes them
Mike Taylor 3601
Old 02-26-2015, 12:25 PM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
Harland Sharp will send you a single rocker that's exactly 1.5 (for example) as a checker. Based on that, they can alter the ratio for an entire set.
Worked for me. -Al
"That'll never work....."
