#11 |
Liked 46 Times in 10 Posts
Fire Sale,
If you car is a convertible then 3369 is correct. If not then 3267 is the shipping weight to use. With the engine rated at 335 the your non convertible would run C @3185 or D @ 3350 or E @ 3520. A convertible would run C @ 3285, D @ 3350, E @ 3520 or F @ 3685. These weight are class minimums. The convertible can't get to the top of C and would have to run 100 heavy for the class.
Ryck Campbell NHRA Technical Specialist |
#12 | |
Liked 237 Times in 126 Posts
As I understand it, GT is like building a car that never came off the production line even though it has the right brand parts in it. So a weight is assigned to the body and the class is determined by the engine factor. It could have been the actual weight of the body used (68 Mustang coupe) or an average 68 Mustang weight, but someone decided on using the heaviest one available. I guess. Dale |
#13 |
Liked 780 Times in 194 Posts
The heaviest coupe weight is 3241, which is what you would use for calculation. You would not use the convertible shipping weight for a coupe body.
#14 | |
Thanks again. Dale |
#15 | |
power to weight factor of the vehicle with the heaviest gasoline engine and appropriate transmission." The vehicle with the heaviest engine is usually the heaviest vehicle, but not always... just something to keep in mind.
Brad Ross - Ross Family Racing #3478 Super Stock |
#16 |
I think the wording is meant to imply the vehicle in question. In this current example the vehicle in question is a 68 Mustang coupe. Don't try to make their wording more technically legalistic than it is. The opening description of the rulebook section states "Cars will be classified using the shipping weight of the body divided by thehorsepower or performance rating of the engine used." The body in that statement is the body you have, not anything else. The intent is to use the heaviest shipping weight of the particular model-body you have. So, for example, you can't use the shipping weight of a 4- or 6-cylinder Camaro when calculating the class when the V8 models were heavier.
#17 |
Hi Guys,
Sorry to hijack this thread but I am in the process of building a GT car of my own and I am new to this class stuff... But anyways, I just wanted to have some sort of clarification or maybe confirmation on what I calculated for shipping weight/classes I can run personally. Here's the combo: LS1 Body style Camaro COUPE (1998-2002) Automatic 327/275HP 1968 Camaro motor (OEM Heads) - 299HP factor (I believe) Using your tips from the templates, If I read correctly, The heaviest coupe is 3370 in 1998. the factor is 12.08 and the HP is 285. So 12.08 X 285 = 3443 (Shipping Weight) divided by my 299 HP is 11.514 which is my base for classes? So I can run the car at 3443 + or - 250. More specifically, my weight would be the minimum ratio for the class X 299HP + 170? I would hopefully just like to confirm this and make sure that I am using the right shipping weights and base ratios (3370 lbs and 12.08) Thanks in advance for the help! JP |
#18 | |
Find your car on the Stock Classification Guide and take the shipping weight from that car's heaviest gas engine with the trans you are going to run. If your body is a 98 Camaro coupe auto, use the shipping weight of the one with the biggest gas engine offered. I don't have data here, but if they sold it with a six and a 427, use the weight of the 427. Once you have your shipping weight, remember what they keep telling me. It never changes, just the factors with different engine combos. Take your shipping weight to the engine listing at the top of the classification guide and divide the weight by various HP ratings to get class factors. Be sure to use the GT factors in regards to HP ratings. Find the posts here about HP weight factors for replacement heads, too. EDIT: LS1 shows up in the Guide starting in 99. You need to pick a year to get the body weight right. It looks like that would be a Z28 coupe with the LS1 engine? I'm a Ford dude... 99 Camaro Z28 Coupe 427 auto weight 3291 327/275HP 1968 Camaro motor (OEM Heads) - 299HP factor (I believe) Yes 3291 / 299 = 11 GT/GA Dale Last edited by FireSale; 12-04-2014 at 03:47 PM. |
#19 |
Thanks Dale!
#20 |
Go to www.classracerinfo.com Register as a user and use the tools there. Much easier, faster.
