Liked 779 Times in 209 Posts
Need some help on a engine for my tow vehicle.
Current engine has 208,000 miles. It's a 6.0L GMC What would be a good route to take ?? Anyone have experience with Jasper Engines ?? Not looking to spend a lot of money either.... Thank you.
"Pistol" Pete Dutko |
Guest
Posts: n/a
What's it doing? Burning oil? Down on power?
If you can have the down time I would say the most economical thing to do IMHO would be to pull it and do a rebuild. Valve seals, springs, cam, lifters, hone, rings, bearings, gaskets, machine work, ... Sounds like a lot cheaper than a new engine. Might be a good time then to add a towing cam and converter while it's apart. Scott |
try dilithium crystals in fusion reactor for impulse engine drive system
Liked 216 Times in 77 Posts
Whats wrong with it? Define "alot" of money. A jasper engine wont be cheap.
#5 | |
I was thinking No More Than $5,000. or is it going to be WAY more than that. Then, probably should look for something with less miles. How bout a junkyard motor with say 70-100 thousand miles ????
Liked 56 Times in 27 Posts
Pete, you have a PM............
Dave Ribeiro 1033 STK |
